Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m Gender: Male Location: Perth Posted 20/07/14 07:27 AM Share Posted 20/07/14 07:27 AM No idea, but if you pop the coil cover off the wire you need is common to all coils and is larger diameter than the trigger wires.Edit: I know Brendan has his now, set up next Saturday at his factory and I'll come and give you guys a hand to fit them. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/6/#findComment-1486503 Share on other sites More sharing options...
foxtrot Member 77 Member For: 16y 7m 14d Posted 12/09/15 07:45 AM Share Posted 12/09/15 07:45 AM Hi. If you are going to use just one coil to wire the tach adaptor in to you may as well just use the negative from one coil and set the "insert device here" to .5 pulses per rev (one pulse per two revs). The autometer unit gives 3 pulses per rev that gives a nice clean signal and a fast enough pulse rate at idle to stop a tach nedle bouncing arourd. Cheers MD Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/6/#findComment-1561381 Share on other sites More sharing options...
