  • Member For: 18y 11m 26d
coils are negative switched as are injectors, but sure the tach adaptor is wired to the positive side and it senses the voltage changes from the coil fields collasping
with the tach adaptor you have to cut the coil power wire and connect it to the tach adaptor in the correct direction of flow, then reconnect the other end of the cut wire to another connection on the tach adaptor, basically so the tach adaptor is in series rather than in parallel
  • Member For: 12y 1m 20d
that's exactly what I've done ratter, same as what the instructions show. But there is no signal at the grey wire. The earth is fine.
It's connected to my E-boost, (I will have to try with a multimeter tomorrow) but the eboost should be picking something up
