Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 22d Gender: Male Location: Perth Posted 03/08/11 05:43 AM Share Posted 03/08/11 05:43 AM On 02/08/2011 at 1:45 PM, 01txr said: Do you have to fit one of these autometer tach adapters to run the eboost2. NopeOr is it required only if you want to set varied boost per rpm. Correct! I'm just looking at running micro switches on shifter lever setting lower boost in 1-3. Good Idea! its right up there on my list of things to do with my car!Would like to know for when I set mine up, if say I run it with varied boost per gears howDo you get around AFR's staying correct on factory Ecu. If your Injector scaling and air flow tables are correct the Pcm will referenace the Base fuel table when in OL so you should get your commanded AFR with the lower boost level.Eg with higher boost in 4-5 gear I will require to more fuel and when it's running less boost in the lower gears it will be running rich because of it. As above mate if your cars tuned correctly it wont be an IssueIs there a boost compensator in the tune that can be set to correct the different levels of boost. There is RPM based compensation built into the units. Its normally used to combat boost creep. With an E-Boost 2 you can set up to 5 Boost groups with different Boost pressures,Wastegate locking pressures, Sensitivies and RPM compensation. You can ramp you boost on smoothly in 1st 2nd and 3rd (and have different levels for each) and Have it come on nice and hard in 4th and 5th.What are the autometer adaptors worth. Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1129197 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 1d Gender: Male Location: QLD Posted 03/08/11 10:20 AM Share Posted 03/08/11 10:20 AM Thanks Luke Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1129401 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 8m 28d Gender: Male Location: NSW Posted 03/08/11 10:49 AM Share Posted 03/08/11 10:49 AM If you have the rpm signal connected you could also use RPM BASED SETPOINT MAPPING which allows you to select the boost level at increments of 500rpm through the rev range which can give you a power curve tailored to your preference. I have a smooth progressive map for track days to limit wheel spin in the 3000rmp to 4500rmp range and an aggressive one for the street which is fun to drive. Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1129415 Share on other sites More sharing options...
GrizzlyF6 Member 87 Member For: 17y 2m 17d Gender: Male Location: Mackay Posted 17/08/11 03:34 AM Share Posted 17/08/11 03:34 AM how did this end up, I'm looking at getting one of the autometer tach adapter (the Ford Racing one is no longer made)Can anyone tell me for sure the Autometer one works??? Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1133748 Share on other sites More sharing options...
383ongiggle Donating Members 53 Member For: 15y 6m 24d Gender: Male Location: Newman, WA Posted 17/08/11 08:07 AM Author Share Posted 17/08/11 08:07 AM On 01/08/2011 at 11:56 AM, foxtrot said: then run the two red wires and the earth wire toward the front of the car to the multi pin plug near the ECU. Is this the plug just outside the "ecu enclosure"?CheersStu Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1133846 Share on other sites More sharing options...
GrizzlyF6 Member 87 Member For: 17y 2m 17d Gender: Male Location: Mackay Posted 24/08/11 01:12 AM Share Posted 24/08/11 01:12 AM On 01/08/2011 at 11:56 AM, foxtrot said: Hi. Mount the autometer tach adapter on the firewall using one stud for the ABS one one side and 2 short self tappers on the other and then run the two red wires and the earth wire toward the front of the car to the multi pin plug near the ECU. On the engine side of the plug locate a heavy red/green (pinky red and pale green) wire and cut this wire about 50 mm from the plug. Join the plug side (ecu side) to the red wire and the engine side to the red/black wire and then run the earth wire across toward the ECU and earth it on the stud that secures the AC pipe behind the ECU. The gray wire can either run across the engine bay with the brake pipes or down to the grommet below the glovebox. All done. Cheers MDHi,would you happen to have any photo's of the multi pin plug you refur to in your post?? Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1135666 Share on other sites More sharing options...
383ongiggle Donating Members 53 Member For: 15y 6m 24d Gender: Male Location: Newman, WA Posted 02/09/11 10:50 PM Author Share Posted 02/09/11 10:50 PM On 01/08/2011 at 11:56 AM, foxtrot said: Hi. Mount the autometer tach adapter on the firewall using one stud for the ABS one one side and 2 short self tappers on the other and then run the two red wires and the earth wire toward the front of the car to the multi pin plug near the ECU. On the engine side of the plug locate a heavy red/green (pinky red and pale green) wire and cut this wire about 50 mm from the plug. Join the plug side (ecu side) to the red wire and the engine side to the red/black wire and then run the earth wire across toward the ECU and earth it on the stud that secures the AC pipe behind the ECU. The gray wire can either run across the engine bay with the brake pipes or down to the grommet below the glovebox. All done. Cheers MDI can confirm that wiring it this way works. Finally got mine done, very happy with the result Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1137219 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 4m 21d Gender: Male Location: Sydney Posted 03/09/11 01:29 AM Share Posted 03/09/11 01:29 AM On 02/08/2011 at 1:45 PM, 01txr said: Do you have to fit one of these autometer tach adapters to run the eboost2. There is RPM based compensation built into the units. Its normally used to combat boost creep. With an E-Boost 2 you can set up to 5 Boost groups with different Boost pressures,Wastegate locking pressures, Sensitivies and RPM compensation. You can ramp you boost on smoothly in 1st 2nd and 3rd (and have different levels for each) and Have it come on nice and hard in 4th and 5th.How does it know which gear you are in?Brian Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1137254 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 1d Gender: Male Location: QLD Posted 03/09/11 01:25 PM Share Posted 03/09/11 01:25 PM Think you run micro switches at gear lever on manuals but not sure about autos. Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1137478 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 2m 9d Gender: Male Location: Gladstone, Queensland Posted 13/07/12 04:08 AM Share Posted 13/07/12 04:08 AM Hi lads, my apologies for reviving an old thread but just curious as to if this is the tach adapter you ended up using to run in conjunction with your eboost2http://www.autometer.com/cat_accessoriesdetail.aspx?vid=99 Link to comment https://www.fordxr6turbo.com/forum/topic/76040-e-boost-tach-adapter/page/2/#findComment-1266766 Share on other sites More sharing options...
