Xe Xr6 Turbo!
acid_rush
  • Member For: 16y 6m 6d
Hey guys haven't been on here for a while been busy building my car. Its a 82 XE GL falcon full taxi pack! hahaha I bought it about 3 months ago its a one owner with 88000kms on the clock, bench seat and column shift auto! In the past few months I have been cracking away at it and hopefully in the next 3-6months it will be full tuned and tearing up WSID! car will now be rocking,
BA Turbo motor with atomic valve springs
Full Billet C4 with Transbrake
3500 TCI converter
Billet Borg Warner diff from SPEEDY (same as his 8.60 Cortina)
Full Spool
Haltech Pro 2000 Ecu
80lb injectors
Plazaman Intercooler and Plenum
Mod wastegate and flapper
4inch Straight thru Exhaust (no cat converter or mufflers)
AI 3litre surge tank with 2x 044 fuel pumps.
Its going to be a sleeper at first to have a bit of fun in will cruize around with the stock 14x6 rims for a bit just to shock people! hahaha also have Weld Draglites for it when I feel serious 15x4 and 15x8.5, Chasing around 370kw@w at first then will take it to the drags and have a few practice runs with the transbrake then give it hell hope to run a mid to high 10 first time out then I will work on the inside as I am leaving that for now. Then I will install a 6point cage, race seats and harnesses all in matching trim followed by a respray....... Then will install the built Atomic motor with 6boost manifold and gt42 then will chase 500kw@w to chase that 9! will upload some photo's soon!
Cheers Brent
  • Banned
  • Member For: 14y 3m 4d
Nice idea mate, and something different :icon_ford:
Not sure if it will manage to be very good sleeper on the street though - 4inch with no cat or mufflers will be extremely loud....! ha ha
Yep, pics would be good. Cheers.
  • Im the one and only
  • Member For: 20y 1m 20d
Cool.Something different.R u planning on any rear end mods other then the diff? 370rwkw and the torque these things make will probably kill a stock rear end.I drove a turbo 250Xflow XE falcon years ago and that was insane so a a barra conversion will be mad. :icon_ford:
  • Banned
  • Member For: 13y 7m 21d
as in good luck on the project.
Will be miricle if you got 370rwkw through a c4 (im guessing that has a convertor) with a standard turbo too not to mention. Due to the car been a little ligher, it may be a bit more forgiving and lasting a little longer before blowing out.
