ratter Member 6,793 Member For: 18y 10m 26d Gender: Male Location: @ my laptop Posted 20/07/11 11:35 AM Share Posted 20/07/11 11:35 AM Does the noise disappear if you have it in gear and load the throttle slightly? Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1124880 Share on other sites More sharing options...
YOZ-F6 Member 96 Member For: 14y 8m 13d Gender: Male Location: Perth, WA Posted 20/07/11 12:24 PM Author Share Posted 20/07/11 12:24 PM yes it does, when it first starts up its bad, but once in drive and moving, its ok..then when I coast the noise comes back, and starts clunking again! what are you thinking?? Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1124887 Share on other sites More sharing options...
Boosted1 Member 346 Member For: 16y 4m 30d Posted 20/07/11 12:37 PM Share Posted 20/07/11 12:37 PM gees mate!!!! I hope for your sake we are all right. but from what you are describing it defs sounds like a flexplate. its quite a common problem once you start pushing some power through the ol 6t. spesh with the zf box. Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1124888 Share on other sites More sharing options...
YOZ-F6 Member 96 Member For: 14y 8m 13d Gender: Male Location: Perth, WA Posted 20/07/11 12:45 PM Author Share Posted 20/07/11 12:45 PM well, the guy who did the mods is CONVINCED its not the bottom end, he got it up on the hoist this arvo, had a good listen to it while it was running, and he's gonna crack open the 'box tomorrow and have a look! I'm really hoping it is just the flex plate, I can't afford a whole rebuild right now! the last thing I want is for a $70k+ car to sit in my garage for the next 6 months while I save for parts Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1124893 Share on other sites More sharing options...
kartman Member 88 Member For: 15y 7m 11d Posted 20/07/11 12:48 PM Share Posted 20/07/11 12:48 PM Jumped a cam gear tooth, exhaust cam duty cycle is 0 at idle and the valves hit the pistons, when the idle is raised the dc goes to 50% and the variable cam control restores cam position based on the cam sensor. Check the cam error at idle with a scan tool.Joel Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1124895 Share on other sites More sharing options...
YOZ-F6 Member 96 Member For: 14y 8m 13d Gender: Male Location: Perth, WA Posted 20/07/11 01:11 PM Author Share Posted 20/07/11 01:11 PM thanks joel! I'll definitly let him know to check that too!Cheers mate! Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1124903 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 26d Gender: Male Location: @ my laptop Posted 21/07/11 12:17 AM Share Posted 21/07/11 12:17 AM (edited) I'm hoping for your sake it's just the driveplate as it sounds like it from your description. If it is do not reuse the driveplate.JoelSaw a tornado once that had jumped 3 teeth on both cams and there was no piston to valve contact, saw a BA that jumped about 15, that was a different story though Edited 21/07/11 12:18 AM by ratter Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1124979 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m Gender: Male Posted 21/07/11 07:14 AM Share Posted 21/07/11 07:14 AM Plus you can get a new fg f6 short here in melbourne for $3000 brand new. If it is the short buy it here in victoria and get your tuner to put it in, should be done for about $2000 to remove and fit motor. Talk about trying to screw people over. Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1125051 Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 16y 2m 17d Gender: Male Location: Victoria Posted 21/07/11 08:10 AM Share Posted 21/07/11 08:10 AM Sounds very much like flexplate to me. I had the same thing happen and I sh*t myself thought it was bottom end gone. The noise would disappear when there was load on it, but at idle it was noisey as hell.Got a new modified flexplate put in from mick at pitlane and its been perfect ever since. Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1125076 Share on other sites More sharing options...
kartman Member 88 Member For: 15y 7m 11d Posted 21/07/11 01:06 PM Share Posted 21/07/11 01:06 PM On 21/07/2011 at 12:17 AM, ratter said: I'm hoping for your sake it's just the driveplate as it sounds like it from your description. If it is do not reuse the driveplate.JoelSaw a tornado once that had jumped 3 teeth on both cams and there was no piston to valve contact, saw a BA that jumped about 15, that was a different story though The vehicle in question was an FG XR6T, jumped only one or two teeth on the crank so both cams were out, I never bothered to look to see if it was a difference in VCT angles in the FG to BA that might make a difference. The top of the guide on the tensioner side breaks off, some investigation found it has happened on more than one occasion through some Ford contacts. I ahve seen a BA do the same without any issue too.Hopefully the flex plate is cracked and that is why the bolts appear tight, it happens on lots of vehicles not just Fords that's for sure, Ive seen the middle crack right out around the crank bolts and the car still drive.Joel Link to comment https://www.fordxr6turbo.com/forum/topic/75929-not-all-engine-noises-are-good/page/2/#findComment-1125220 Share on other sites More sharing options...
