Bad Idle Bf Turbo
jonn
  • Member For: 16y 28d
hi, ive got a problem with my idle.
once warmed up the car vibrates. stronger then usual, and only at idle.
no idea what it could be,
ive had it looked at by my tuner and the cars idle a/r are perfect, sits on 650-710rpm consistant
giving it accelerator to 800rpm the vibrating stops
if im rolling in neutral it doesnt feel to be vibrating
theres no surging, backfire, accelerates normal.
the sparkplugs are only 20,000 kms old and ive checked all the gaps
its not a vacuum leak
ive cleaned out the TB and the gasket is fine.
changed the oil
engine mounts look to be in place
anything im missing? doing my head in
  • Member For: 17y 2m 3d
If you have a timing light, try it on each coil. Sometimes these things seem fine, but under load they crap out. Could be a dud plug, same reasons. If you kept the old plugs/coils,just swap em 1 by 1 till it stops.
  • 2 weeks later...
yeh under load its smooth and pulls as hard as ever, when on idle.. its crap.
might aswell put the old ford plugs back in and see if it makes a difference.
cars.... such a waste of time lol
