GinjaNinja Member 125 Member For: 15y 8m 6d Gender: Male Location: SEQ Posted 13/07/11 01:38 AM Share Posted 13/07/11 01:38 AM Hi folksI consulted few workshops in regards to replacing the current heat exchanger and I've asked for ideas, further suggesting if I should fit the f6/territory unit on my xr6t and it seems all workshops have said to stick with the standard xr6t ones as they don't know if it will be a direct fitCan anybody elaborate on this? The fpv unit seems to a bit thicker and I wonder if this will fit onto normal xr6t'sSuggestions will be full appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/ Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 10m 4d Gender: Male Location: Sydney Posted 13/07/11 09:18 AM Share Posted 13/07/11 09:18 AM On 13/07/2011 at 1:38 AM, GinjaNinja said: Hi folksI consulted few workshops in regards to replacing the current heat exchanger and I've asked for ideas, further suggesting if I should fit the f6/territory unit on my xr6t and it seems all workshops have said to stick with the standard xr6t ones as they don't know if it will be a direct fitCan anybody elaborate on this? The fpv unit seems to a bit thicker and I wonder if this will fit onto normal xr6t'sSuggestions will be full appreciated I have an FGXR6T ZF and changed to the bigger F6 heat exchanger with more plates no worries. Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1122712 Share on other sites More sharing options...
Barra Donating Members 467 Member For: 16y 5m 15d Gender: Male Location: Toowoomba Posted 13/07/11 09:49 AM Share Posted 13/07/11 09:49 AM What did the F6 heat exchanger cost you? I think this is a good idea as it still looks stock. Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1122724 Share on other sites More sharing options...
GinjaNinja Member 125 Member For: 15y 8m 6d Gender: Male Location: SEQ Posted 13/07/11 11:32 PM Author Share Posted 13/07/11 11:32 PM (edited) On 13/07/2011 at 9:18 AM, nelsonian101 said: I have an FGXR6T ZF and changed to the bigger F6 heat exchanger with more plates no worries.Oh I get it, it's actually swapping the cooler too and not just the piping. I had originally thought it was the piping that caused the leaking.So do u have to buy the parts separate or do they come in a kit??? Edited 13/07/11 11:44 PM by GinjaNinja Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1122848 Share on other sites More sharing options...
GinjaNinja Member 125 Member For: 15y 8m 6d Gender: Male Location: SEQ Posted 13/07/11 11:51 PM Author Share Posted 13/07/11 11:51 PM Sorry for my ignorance but any suggestions and tips will be appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1122851 Share on other sites More sharing options...
GinjaNinja Member 125 Member For: 15y 8m 6d Gender: Male Location: SEQ Posted 14/07/11 04:12 AM Author Share Posted 14/07/11 04:12 AM OK went to Fraud to pick up the f6 cooler unit (223 bucks) and also found out u had to replace the pipes leading from the radiator/waterpump to the trans cooler (they now come with a 1 unit metal piping, which is supposed to be re-fitted to the BF's on request) The new piping from the radiator/water pump is to replace the old units which were plastic and were prone to leakingso all up about 320-330 on parts alone Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1122916 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 13d Gender: Male Posted 14/07/11 04:15 AM Share Posted 14/07/11 04:15 AM U can just cut the front section off the new water pipe Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1122917 Share on other sites More sharing options...
GinjaNinja Member 125 Member For: 15y 8m 6d Gender: Male Location: SEQ Posted 14/07/11 02:59 PM Author Share Posted 14/07/11 02:59 PM What do u mean by cutting the front section off the new water pipe?What is the purpose of this so the new unit will fit where the existing one was to be?Please elaborate Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1123167 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 13d Gender: Male Posted 14/07/11 08:42 PM Share Posted 14/07/11 08:42 PM The idea is to replace the leaky plastic bypass valve. Unless you want to remove your whole intake, you can just replace the front section and leave the original rear section which runs behind the cylinder head.I was going to do this myself but because of no play time situation with new baby and toddler I got Autotech to do it who agreed it was the best way. Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1123183 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 10m 4d Gender: Male Location: Sydney Posted 14/07/11 11:20 PM Share Posted 14/07/11 11:20 PM I was one of the first to get a preordered FGXR6T mid'08 when they first came out. Originally on the options list you could get an Auxillary Oil cooler for about $200. Ford stuffed, bigtime. I ticked the box but received nothing as all ZF's come with the smaller yellow dot heat exchanger. I complained, as a few others did and got the whole Police Pack free which included the oil cooler/heat exchanger below and bigger ZF heat exchanger. Now, I repalce them every 2 years as the alloy is low quality and I don't want my coolant mixing with transmission fluid any time soon.There is also an sandwich oil cooler/heat exchanger as part of this pack between block and filter which comes part of the Police pack on FG and is stock on F6. Link to comment https://www.fordxr6turbo.com/forum/topic/75827-replacing-heat-exchangerscooler-bypass-for-zf-xr6t/#findComment-1123214 Share on other sites More sharing options...
