R33 Skyline
WHITER33
  • Member For: 13y 10m 30d
I know its not a :icon_ford: but you might be interested in my Datsun.
This is how the first round of mods ended up
Car: Nissan Skyline R33 GTS-T
Engine: RB25DET
Engine mods: TD06-20G turbo on high mount manifold
Tomei cams and cam gears
Forged pistons
Blitz external wastegate and screamer pipe
Blitz fmic
Haltech E11V2
Splitfire coils
Exhaust: 3 inch from turbo
Gearbox: Standard
Clutch: Custom single plate 3700lb
Diff: Gtr mechanical lsd
Suspension: Tein
Wheels: 18 inch 245 tyres
Stereo: Alpine IVA-D300E 7" touch screen dvd
Pioneer TS-A1680S 220w front
Pioneer 6x9 rear
Was:
Power: 269.6rwkw @14.2psi
Performance: 12.426 @ 117.04mph
102-0207_IMG.jpg]
I got bored with the single TD06 turbo and fitted a custom twin setup for something different. lol
This is with a 3lt bottom end and RB25 head.
In the car.
Changed plans again and pulled the twins off and added this
Mounted off one of these 6boost manifolds
And you guessed it. Changed plans again.
Now have a built 26/30
The first 26/30 made 420rwkw @ 19psi on 98 pump fuel and with a 50/50 mix 98/avgas made 475rwkw @ 24psi.
We then found a major oil problem that caused some bad damage. End result was a bent crank, spun bearings and damaged block.
The next 26/30 has just been fitted and will hopefully be fired up in a few week.
Will be running 2000cc injectors and E85 so should make 500+
Edited by Dagabond
  • Member For: 16y 10m 16d
Awesome result man, when does it come on boost?
I'm guessing the kit was probably "in" when you put it on and you've owned it a while? Agree the body could be alot tidier but with 500kw who cares.
  • A much better forum
  • Member For: 16y 6m 13d
It's good to see a Skyline in decent nick... Everything I see on the street now is a sh*tter with a young chick or bloke driving it...
I don't mind the bonnet, but the rear wing is terrible! Might be why you were only running mid 12's :stirthepot:
