dragonf6 Member 17 Member For: 13y 9m 10d Posted 09/07/11 06:11 AM Share Posted 09/07/11 06:11 AM Hi all,I have a FG F6 with a custom tune, 4' dump, high flow cat & standard cat back exhaust. It's making 302rwkw on 11 psi. I want to get a little more but don't want to sell the farm. The tuners in Brissy say that I need to spend 5k on: full cat back new exhaust, upgrade injectors, upgrade fuel pump, upgrade intercooler etc...It's all very confusing - is there a better value for money way for more gain without the pain? I was thinking a new cat back exhaust only but am open to sugestions.Questions:1. Do I need to change injectors & fuel pump if I go for a 3.5" single cat back system? (been told I do)2. What gives me a little more bang for my buck - say 330 - 350rwkw?3. Is a intercooler really necessary for 330 - 350rwkw?Any value for money ideas would be appreciated.Cheers Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 11m 11d Gender: Male Location: Vic Posted 09/07/11 06:49 AM Share Posted 09/07/11 06:49 AM An intercooler really is needed. Also you'll be needing injectors. $500 injectors$2k for a cooler kit fittedRe tune. $3k. Should see 350 IMO. Catback, surge tank and fuel pump, should see 400 me thinks. Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 6m 12d Gender: Male Location: Zombie Birdhouse Posted 09/07/11 07:11 AM Share Posted 09/07/11 07:11 AM Intemercooler a must IMO to prevent heat soaksome 60lb Dekas or similar squirters.don't worry about the zorst as a high flow cat should free up the stock set up.If a sedan I would recommend a surge tank for 300rwkw plus for insurance Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 9m Gender: Male Location: Adelaide Posted 09/07/11 07:37 AM Share Posted 09/07/11 07:37 AM nar bud your gunna get raped just deal with it Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 9m 5d Gender: Male Location: Melbourne Posted 09/07/11 07:52 AM Share Posted 09/07/11 07:52 AM On an F6 I would just do injectors and retune, might also be worth changing the intake piping too alloy as the plastic ones tend too break once boost is raised.Let the dyno queens worry about heatsoke for the moment, but if your budget is 5k then yeah full intercooler kit would be you next step. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 4d Gender: Male Location: @ my laptop Posted 09/07/11 07:56 AM Share Posted 09/07/11 07:56 AM Heat soak will show as more of a problem on the street or strip. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 10m 5d Gender: Male Location: Victoria Posted 09/07/11 08:07 AM Share Posted 09/07/11 08:07 AM Let the dyno queens worry about heatsoke for the moment, but if your budget is 5k then yeah full intercooler kit would be you next step.Better cooling means denser air which means more timing can be dialed in with intake, combustion and exhaust temps being lower.Better flow and less pressure drop is another advantage which reduces stress on the turbo and improves throttle response and overall performance.Getting the air in and the exhaust out as efficiently as possible means the engine will make power easier and hold that power for longer.Intercooler is worthwhile at any level of modification. Link to comment Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 3m 8d Gender: Male Posted 09/07/11 08:27 AM Share Posted 09/07/11 08:27 AM (edited) F6s already have greay rwkw, let alone with high-flow cat and "tune"....initial stage seems ordinary. Intercooler/exhaust/injectors - the next tune should see real gains. Edited 09/07/11 08:39 AM by CBXRT Link to comment Share on other sites More sharing options...
dragonf6 Member 17 Member For: 13y 9m 10d Posted 09/07/11 10:15 AM Author Share Posted 09/07/11 10:15 AM Thanks for the feedback. And yes, with what's been done so far the rwkw's do seem a little ordinary. Think I should be getting a little more rwkw with the current stage? Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 9m 5d Gender: Male Location: Melbourne Posted 09/07/11 10:50 AM Share Posted 09/07/11 10:50 AM Adam I agree, but on the street (maybe 10-15 mins between extended WOT) driving through cold air I think an exhaust will help the turbo produce more power then a cooler.If you put a full intercooler kit on an stock exhaust or a full exhaust and stock intercooler it's obvious which will make more power.I don't think "back to back" is that important for street cars as your not on WOT 100 or even 10% of the time.Just my 2c Link to comment Share on other sites More sharing options...
