fanatik Member 18 Member For: 14y 3m 14d Posted 08/07/11 08:43 AM Share Posted 08/07/11 08:43 AM he everyone,I have had my fg turbo for about 4 months now and after having to get work done on the turbo I finally have the money to do some work on the engine. I have been quoted the following..sniper tuneinjectorsfuel pumpactuatorfuel pumpdyno time these mods apparently should give me just over 400hpand this has all come to $3600. Its more then I planned spending for this seeing as I also want to do the cold air, fmic, exhaust.Just seeing what everyones thoughts are about if this is the way to go, and reasonable price. Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/ Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 3d Gender: Male Location: Melbourne Posted 08/07/11 09:02 AM Share Posted 08/07/11 09:02 AM That seems extremely expensive for essentially no bolt on parts just a tune.X3 Flash box, injectors, high flow cat, replacement alloy intercooler piping and tune should be roughly same price maybe a bit cheaper and seems to be a more realistic approach. But that's just my opinion. Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1121228 Share on other sites More sharing options...
Brandon18 Member 54 Member For: 15y 4m 10d Gender: Male Posted 08/07/11 09:07 AM Share Posted 08/07/11 09:07 AM https://www.plazmaman.com/shop/?action=listCategoryItems&catId=12Have a look on here mate pick a kit, get a flash tuner and a set of injectors to go with should set u back 1750 at worst I would think and you should see some decent power, more the the car will probly feel alot better to drive I would think Who was that quote through may I ask ? Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1121230 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 9d Gender: Male Location: Vic Posted 08/07/11 09:09 AM Share Posted 08/07/11 09:09 AM That sounds farkin steep for a sniper tune and those mods, also seem like random mods as well. Why sniper?Ild doXcal 3 $750Custom tune $750Injectors fitted $500Cat fitted $350$2350 and should see ~300rwkw. Then $999 for a Pwr cooler $600 for a "stainless 4" intake and battery relo"Should max the stock turbo at ~320 Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1121231 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 5m 2d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 08/07/11 09:12 AM Share Posted 08/07/11 09:12 AM (edited) could save money by only getting one fuel pump. (dont think you even need that )with that money add the coolerworx piping to henz list and you will be a very happy camper...p.s. On 08/07/2011 at 9:09 AM, henz said: Should max the stock turbo at ~320he's talkin bout rwkw not hp Edited 08/07/11 09:19 AM by STAINLESS Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1121233 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 3m 28d Posted 08/07/11 09:13 AM Share Posted 08/07/11 09:13 AM Pretty sure the fuel pumps on FGs are pretty good. Injectors im not too sure but thought they were pretty good too. Maybe go a high flow cat,intercooler,intake and better piping and then tune. Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1121234 Share on other sites More sharing options...
fanatik Member 18 Member For: 14y 3m 14d Posted 12/07/11 10:52 AM Author Share Posted 12/07/11 10:52 AM I called them up today they said the price was high because its a ute which makes it harder to install the fuel pump.Anyway in W.A who have tuned and modded please let me know where you went and what you got ok so here is the actual quote and prices...injectors 60lb/hr $518spacers 20mm $ 13.64actuator 12.7 psi t25 2" $ 140.59actuator ext rod $ 23.04coolant $76.19mechanical labourt $500pump elec fuel $325pump plug and harness $31hose fuel submersible line $48.20thermostat $35mechanical labour $400sniper interface $ 495custom tune $395dyno use $436 Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1122433 Share on other sites More sharing options...
fanatik Member 18 Member For: 14y 3m 14d Posted 12/07/11 10:56 AM Author Share Posted 12/07/11 10:56 AM I work a couple doors down from BPT who use the sniper interface so it was the easy choice, I just pushed the installs off for 2 weeks whilst I decide what I am going to do. On 08/07/2011 at 9:09 AM, henz said: That sounds farkin steep for a sniper tune and those mods, also seem like random mods as well. Why sniper?Ild doXcal 3 $750Custom tune $750Injectors fitted $500Cat fitted $350$2350 and should see ~300rwkw. Then $999 for a Pwr cooler $600 for a "stainless 4" intake and battery relo"Should max the stock turbo at ~320 Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1122436 Share on other sites More sharing options...
fanatik Member 18 Member For: 14y 3m 14d Posted 12/07/11 10:57 AM Author Share Posted 12/07/11 10:57 AM On 08/07/2011 at 9:13 AM, ebxmple said: Pretty sure the fuel pumps on FGs are pretty good. Injectors im not too sure but thought they were pretty good too. Maybe go a high flow cat,intercooler,intake and better piping and then tune.becuase I am gonna do the whole cooler I am not gonna bother doing the piping Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1122437 Share on other sites More sharing options...
fanatik Member 18 Member For: 14y 3m 14d Posted 12/07/11 11:00 AM Author Share Posted 12/07/11 11:00 AM On 08/07/2011 at 9:07 AM, Brandon18 said: https://www.plazmaman.com/shop/?action=listCategoryItems&catId=12Have a look on here mate pick a kit, get a flash tuner and a set of injectors to go with should set u back 1750 at worst I would think and you should see some decent power, more the the car will probly feel alot better to drive I would think Who was that quote through may I ask ?BPT motorsport in Wangara Link to comment https://www.fordxr6turbo.com/forum/topic/75738-mods/#findComment-1122439 Share on other sites More sharing options...
