Engine Running Really Rough
  • Member For: 21y 6m 25d
Hi Guy's and Gal's
Gave my T a firm squirt when merging off a freeway (didn't hit the rev limiter) but the car ran on what was about 3 cylinders for about 10 secs, no power, lumpy as hell and I almost had to pull over (very embarassing!!)
The car has 7000 kms on it.
Anyone had this experience?
Cheers,
Rick
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
  • Member For: 22y 4m 23d
  rakrzy said:
Hi Guy's and Gal's
Cheers,
Rick
Yes,
And the same siruation, I had been travelling on a secondary road, pulled onto the freeway at night looked around and no=one there - so into the throttle but not nailing it.
It died!!
Limp home mode all of a sudden while I thought about my options. Pulled over and turned it off, thought "please go baby" and turned it back on. No problem off we went.
It happened once again a while ago, overtaking, wanted to go from about 9- klms/hr so depressed the throttle. Limp home mode again. That was actually really annoying.
And,
If you were someone who was relying on the power because you went for a small gap when overtaking - suddenly you are relying on the brakes! Shudder anyone?
Me? No, I just watched the bewidered look on the octerian with the caravan (hate those things) as I braked back behind him.
  • Member For: 21y 5m 8d
Hey people
I've had similar overflow probs when starting my baby up but nothing a little idling wont take care of.
I've had the vaccume hoses come off twice ... you may want to upgrade the clips!
uhh.. the heat shield is rattling in idle at the moment lol
only other probelms is when I forget to take of the traction control and floor it :censored:
  • zeke
  • Member For: 21y 10m 9d
There has been a previous thread on this called (I think)
"dangerous loss of power".
It is a major concern and needs to be adressed and a definitive solution found. To lose power during an overtaking move is potentially disastrous and there is no way the "software" should allow the car to deliver less than the maximum urge available while the accelerator is flat to the floor. OK, flash some warning lights, sound chimes etc, but don't cut the power until the foot is off the loud pedal - seems sensible to me!
I can't really understand why this topic hasn't caused ongoing interest. At least the brake issues give some warning. Maybe it's only people who do a lot of country driving on B-class roads get excited about this - but one of the reasons for buying a T was the fact that accelleration means less time on the wrong side of the road. If the fire goes out without warning, all the T's accelleration performance does is give confidence that could prove false with tragic consequences!
Yes, my T has done this twice in 4500k, the last time about a week ago when it suddenly stalled while driving in peak hour traffic at abut 50 kph. First noticed due to the steering getting heavy! Restarted straight away and no indication of any ongoing problem.
zeke
  • Member For: 21y 5m 28d
some would say overtake when safe to do so, not leaving no margin for error because its that crazy little thing called error gets us everytime
Guest wannabe
  • Guests
the problem is there is no way to allow for this 'error'. This is probably the major worry for me in my plans to buy an XR6T
