Impellor Member 835 Member For: 14y 10m 29d Gender: Not Telling Posted 07/07/11 09:23 AM Share Posted 07/07/11 09:23 AM (edited) Well I have just spent the last two days doing a defensive driving course at the Roadcraft driving centre in Gympie provided at my employers expense. I found this an extremely worth while experience, as now I understand far more about driving techniques, and how tyre pressure improves vehicle handing and braking. Anyway, to my horror the instructor told me to get the best out of the car I needed to put 48 psi in the fronts, and 44 in the rears. I said "that will surely wear the tires out quicker" his reply was actually this will give them a maximum tyre life. He then informed me that by actually lowering the car and using stiffer springs would also reduce the cars handling capability. He said that with his rally car he would find the softest standard springs he could find and then use a good quality shock. He then highlighted that he felt that the biggest rim he would use was 17 inch, stating that this was the size as used by V8 Supercars. So now he had my attention, so I asked why. His reply was that by using a 17 inch wheel and a reasonable profile it allowed for greater vehicle feedback. That by using large wheels and ultra low profiles the driver is never given any warning when the grip level capabilities are achieved, in his words it will just let go. Further he highlighted that under controlled braking tests a VE Late model camira with FE2 suspension, had a greater braking distance than a non FE2 car. His explanation was based on the vehicles inability to transfer 70% of its weight into the front suspension, thus reducing front end grip.Anyway I found that the car was better balanced with the increased pressures. Also after day one of driving to Gympie hitting the skid pan then driving home, I was averaging 13.7 l/100kms. Today after putting 48/44 psi in the tires I averaged 11.3(and today the car copped a thrashing compared with yesterday). Now if you wish to debate this you are more than welcome to ring Mark at Roadcraft Driver Training you can 0n 54828833. He also informed me that if you would like to do so skid pan work ring him I he can supply a number for individuals that would like to join in. Just to finish I invited Mark to take my car for a few laps. He was very impressed by the grip and feedback the car had for its size, and also commented on how torquey it was down low. Bridgestone are a major sponsor and he also stated that they provide extensive information on tyre wear and performance, so he is well worth taking to about tyres and suspension, and how these interact with vehicle dynamics. Anyway I thought that I would share this will you, as I found it all very suprising, but please understand I don't what to argue, if you have any issues ring the expert because I am not, Cheers Edited 08/07/11 10:12 AM by RHR para...WHAT?? Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/ Share on other sites More sharing options...
chippa Slippery when dry Donating Members 368 Member For: 17y 11m 6d Gender: Male Location: Foot Hills W.A Posted 07/07/11 09:53 AM Share Posted 07/07/11 09:53 AM Dude have you heard of paragraphs????.... hahaha and 2nd never inflate past your cold max pressure..... Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1120954 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 10m 29d Gender: Not Telling Posted 07/07/11 10:05 PM Author Share Posted 07/07/11 10:05 PM (edited) Right you are . Never inflate over manufacturers maximum pressure.Cheers Edited 08/07/11 10:12 AM by RHR No need to quote above post. USE FAST OR ADD REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1121065 Share on other sites More sharing options...
xr6greg Member 73 Member For: 16y 11m 29d Posted 08/07/11 07:11 AM Share Posted 08/07/11 07:11 AM He then informed me that by actually lowering the car and using stiffer springs would also reduce the cars handling capability. He said that with his rally car he would find the softest standard springs he could find and then use a good quality shock.Yes. But I tend to drive on bitumen roads in a street car which requires stiffer suspension than that of a rally car going sideways around dirt corners over pot holes?He then highlighted that he felt that the biggest rim he would use was 17 inch, stating that this was the size as used by V8 Supercars.Does Mark know that V8 supercars are looking at going to 18 inch rims to improve their handling?Most experienced drivers, and 'experts', will recommend (depends on the brand of tyres of course) that a 40/45 profile tyre should be inflated to about 40/42 psi for street use. The 32/36 psi recommended by the car manufacturer is the best for making the car feel 'smooth' when you are dropping the kids off at school. Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1121183 Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 7m 20d Gender: Male Location: Melbourne Posted 16/07/11 03:42 PM Share Posted 16/07/11 03:42 PM 32 to 36 is horrible. I run 40 all round and notice a big difference. Don't think I would go over that though, especially for around town driving. Jarred back and extra rattles anyone? Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1123727 Share on other sites More sharing options...
Barra Donating Members 467 Member For: 16y 7m 5d Gender: Male Location: Toowoomba Posted 16/07/11 04:50 PM Share Posted 16/07/11 04:50 PM (edited) I normally run on between 46-48 psi, inflated when tyres are cold. Max is 50psi on my current tyres. I drive on alot of hwy and rough roads and getting good wear and feedback from the road.Rattles arent that bad for me.. Edited 16/07/11 04:52 PM by Barra Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1123730 Share on other sites More sharing options...
Barra Donating Members 467 Member For: 16y 7m 5d Gender: Male Location: Toowoomba Posted 16/07/11 04:53 PM Share Posted 16/07/11 04:53 PM Impellor, What size and profile tyres are you running.? I use 245/35/19. Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1123731 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 5m 22d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 16/07/11 05:56 PM Share Posted 16/07/11 05:56 PM (edited) When I had 40psi and clutch kicked 3rd at 80kmh the rears would light up violently and the car would shoot across 3 lanes. Now with 25psi its still violent but stays straight. The kids feel much safer on the way to school. Edited 16/07/11 05:57 PM by STAINLESS Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1123734 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 10m 29d Gender: Not Telling Posted 16/07/11 06:03 PM Author Share Posted 16/07/11 06:03 PM Standard, 17, 235, 40. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1123735 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 10m 29d Gender: Not Telling Posted 16/07/11 06:55 PM Author Share Posted 16/07/11 06:55 PM (edited) On 08/07/2011 at 7:11 AM, xr6greg said: He then informed me that by actually lowering the car and using stiffer springs would also reduce the cars handling capability. He said that with his rally car he would find the softest standard springs he could find and then use a good quality shock.Yes. But I tend to drive on bitumen roads in a street car which requires stiffer suspension than that of a rally car going sideways around dirt corners over pot holes?He then highlighted that he felt that the biggest rim he would use was 17 inch, stating that this was the size as used by V8 Supercars.Does Mark know that V8 supercars are looking at going to 18 inch rims to improve their handling?Most experienced drivers, and 'experts', will recommend (depends on the brand of tyres of course) that a 40/45 profile tyre should be inflated to about 40/42 psi for street use. The 32/36 psi recommended by the car manufacturer is the best for making the car feel 'smooth' when you are dropping the kids off at school.It does appear that V8 supercars may go to 18 inch rims late in 2012. Although from the info I have read its got nothing to do with handling. It is mainly to do with cost saving. That is bigger brakes for reduced brake pad changes, and opens the market up on obtaining cheaper control tyres. One article highlights that they have stuck with the 17's since 1993 because they like them. But as I said in my 1st post give the expert a ring as the number has been supplied. You never know, you might know more than him. Cheers Edited 16/07/11 06:56 PM by Impellor Link to comment https://www.fordxr6turbo.com/forum/topic/75715-tyre-pressures/#findComment-1123736 Share on other sites More sharing options...
