  • Carnage on the Garage Floor
  • Member For: 14y 11m 3d
  On 11/08/2011 at 8:32 AM, FG50T said:
Would a generic trans tune work? Just a simple one for people that want don't want anything specific besides the operation 'cleaned up' a little bit? Charge half the price of the tune and load it up in 5 mins?
give it twelve months and this will be the norm for most tranz tunes IMO.
  • Member For: 14y 9m 27d
No warranty would be given on the hardware of the transmission, as always with any calibration if you are not happy with the way the transmission has been calibrated take it back to the tuner who done the job.
Herod has thrown everything into his test cars and in nomral conditions nothing will go wrong with the hardware , if anything higher shift pressures will ensure longer life. we have given you guys the tools that have been needed to have your trans calibrated and the only way you can have your trans calibrated is by a tuner that has done training with herrod and is accredited, we have done this to protect you the end user.
  • G666E Turbo!!!
  • Member For: 15y 2m 29d
sct is there anyway to enable the mode that the auto disconnects the torque convertor in D with foot on brake
sounds like a noob stupid question, but I read somewhere that our ZF has the ability to disengage? the torque convertor in drive with foot on brake... sounds silly and its probably not the correct terminology, but im surprised its not a feature included from factory, in D my car will sometimes sit @ 2.3L/ph put it in N and it will drip to 1.6L/ph both with the ac running
  • Member For: 17y 4m 21d
Yeah I roll up to lights as far as I can in N to save fuel :) on the long waits in traffic leaving work it probably saves 300ml or more a day!
Oh but I stick the handbrake on after stopping so unless the ZF can disengage totally from park brake signal as well it won't help me as much. Sitting on the brake pedal is to be avoided if you've just pulled up hard and put some decent heat into the pads...warps rotors.
Edited by -SteveR-
  • Here since the start...
  • Member For: 21y 11m 19d
That's not how a torque converter works. It's a fluid coupling.
  • G666E Turbo!!!
I understand how it works I was trying to quote the article I read from memory, I will google it to see if I can find it if I can be bothered, afaik there is no mechanical connection to the box from the shifter, so it may be a simple switch into N when foot is on brake and back into D when brake is off, at idle...
It was an article specifically about the FG ford and ZF, can't remember the source
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 14d
just thought id mention my car has been done "tuned" and its sick even managed a 2nd gear chirpie across the lights :buttrock:
  • Thooperrrrrrr
  • Member For: 13y 9m 12d
If you were to get the ZF tuned before the engine tune, would you need to get the ZF re-tuned at a later stage or does it make no difference whether you do it before or after?
Good question! Never thought of it being done the other way around.
