TITO Member 42 Member For: 16y 7m 28d Gender: Male Location: Sydney Posted 04/09/14 08:39 AM Share Posted 04/09/14 08:39 AM Good video on Daniel's bushes mine have been fitted at around 3000 klm on my 2010 fg f6 manual and my diff clunking became obvious with the new bushes. I only replaced them to stop axle tramp and because the manual cars really explode compared to auto cars I suppose if I fitted the new factory bushes you get rid of the noise but once they soften up after a few thousand k's get ready for axle tramp. The diff are rubbish in fg's and Daniel has a rebuilt diff in his car that's why its quiet.What type of oil did you use in the diff? I used Mainlube and I want to try something else. Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1497155 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 1m Gender: Male Location: Perth Posted 04/09/14 09:03 AM Share Posted 04/09/14 09:03 AM On 17/08/2014 at 11:45 PM, XRSEXT said: My rear centre bush is cracked.. Not even bothering going to Ford for a replacement under warranty, fitting K-mac bushes centre and 2 side bushes on Wednesday, fingers crossed, these look like some heavy duty bushes!!How did you get on with the K-mac bushes mate? Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1497160 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 4d Gender: Male Posted 04/09/14 11:39 AM Share Posted 04/09/14 11:39 AM (edited) On 04/09/2014 at 8:39 AM, TITO said: Good video on Daniel's bushes mine have been fitted at around 3000 klm on my 2010 fg f6 manual and my diff clunking became obvious with the new bushes. I only replaced them to stop axle tramp and because the manual cars really explode compared to auto cars I suppose if I fitted the new factory bushes you get rid of the noise but once they soften up after a few thousand k's get ready for axle tramp. The diff are rubbish in fg's and Daniel has a rebuilt diff in his car that's why its quiet.What type of oil did you use in the diff? I used Mainlube and I want to try something else.I used the full synth castrol stuff SAF-XA which is also for lsd's. I'll have to rebuild the diff though as the noise will eventually drive me crazy... Bring on a Moser wavetrac I say!You're right about the manuals being hard on the diff's. My diff used to tramp so hard the thing sounded like it was coming through the rear floor pan! Wet or dry weather made no diff! Its awesome now Edited 04/09/14 11:40 AM by demon1300 Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1497204 Share on other sites More sharing options...
FormulaFG Donating Members 68 Member For: 10y 9m 26d Posted 16/10/14 11:39 AM Share Posted 16/10/14 11:39 AM On 28/08/2014 at 9:02 AM, demon1300 said: Here's a quick vid I shot about a month ago of my CAT600 bushes: Great video.Can I ask what you type of camera you used and how you mounted it. I would like to make a couple similar myself.Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1506477 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 8m 23d Posted 17/10/14 12:37 AM Share Posted 17/10/14 12:37 AM So I ended up fitting superpro race sides with a comfort centre, stopped all the tramp I was having. Been in for 2 weeks and have already split the centre. They are perfectly quite though. Might have to bite the bullet and fit a solid center, then break the bolt, then the hat, then the cradle. Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1506564 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 4d Gender: Male Posted 17/10/14 05:17 AM Share Posted 17/10/14 05:17 AM On 16/10/2014 at 11:39 AM, FormulaFG said: Great video.Can I ask what you type of camera you used and how you mounted it. I would like to make a couple similar myself.Thanks.I used my gopro 3. Stuck a mount to the spare wheel tub On 17/10/2014 at 12:37 AM, gaz097 said: So I ended up fitting superpro race sides with a comfort centre, stopped all the tramp I was having. Been in for 2 weeks and have already split the centre. They are perfectly quite though. Might have to bite the bullet and fit a solid center, then break the bolt, then the hat, then the cradle.I reckon these will be quiet. I think all my noises that I've been complaining about with the CAT600 bushes have been diff related...I don't think you can go wrong with his bushes. With his outers being so solid, the middle had very little preload on it and hence won't break the bolt. Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1506626 Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 8m 23d Posted 17/10/14 05:40 AM Share Posted 17/10/14 05:40 AM I can't see the difference between superpro race sides and the cat sides. With the superpro have 2 small voids and that's it. I think I just need to stiffen up the centre a tad more to get the setup right between firmness and longevity. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1506635 Share on other sites More sharing options...
bens-xr6t New Member 19 Member For: 11y 9m 14d Posted 24/10/14 12:47 AM Share Posted 24/10/14 12:47 AM Hi guys Just had the diff bush replaced with a solid one and all other bushes in the rear end done too. Now just on take off I can hear clunking in the back of the car the mechanic said it was the diff was on it way out. But then I took it to the ford dealership and they say nothing is wrong with it. ??? Could this be the backlash or what. Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1507884 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 1m Gender: Male Location: Perth Posted 24/10/14 02:01 AM Share Posted 24/10/14 02:01 AM Yep, pretty common with solid bushes bud...unfortunately. Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1507892 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 4d Gender: Male Posted 24/10/14 05:36 AM Share Posted 24/10/14 05:36 AM It'll be the diff backlash. Get under it quickly and try and rotate the half shafts. Guaranteed one will turn slightly and make a clunk. Link to comment https://www.fordxr6turbo.com/forum/topic/75681-fg-diff-bush-replacement/page/9/#findComment-1507929 Share on other sites More sharing options...
