  • Member For: 13y 11m 2d
Hi all,
Just had problem with my car being diagnosed as a wastegate fault issue. Apparently it needs to be replaced with a new one. My car is completely standard running factory boost so I will need to replace it with a similarly sized actuator so I dont have to have the car retuned.
Ford do not supply these without the turbo attached so sourcing one from Ford is impossible!
Does anyone out there have a resonably new Wastegate Actuator that they want to part with, or where can I find a factory sized actuator?
I need to get this problem sorted.
Cheers
https://www.fordxr6turbo.com/forum/topic/75598-factory-watsegate-actuator/
  • Member For: 15y 7m 5d
Try contact a few tuners close to you. One is bound to have an old actuator laying around after doing an upgrade on a customers car.
I am in Cairns, I have been to two 'tuners' so far and niether seem to care about what needs to be done. It's hard to find good service up this way.
  • Member For: 17y 11m 20d
There's heap on Ebay mate or even Chris (Rapid Systems) has a deal on ATM I think. He's a forum sponsor so check out his website for details.
  • Moar Powar Babeh
  • Member For: 19y 7m 22d
There's myriad of faults that the PCM will label "wastegate actuator fault" and it's rarely the actuator.
Get it checked put by somebody in the know.
Most of our sponsor will be able to supply you and actuator they are usually less than $100
  • Bronze Donating Members
  • Member For: 14y 20d
I had one of these go on my car under warranty and Ford told me they had to order one in from MTQ (Turbo Specialists). Not sure if they sell direct to the public but might be worth a shot. They have quite a few locations in QLD. link to MTQES
  • Moar Powar Babeh
Mtq do have a retail dept either goto a branch or check out sonic performance
  • Member For: 15y 6m 20d
If you are in cairns I can ask these "tuners" for you. I actually just sold an actuator a couple months nack for $25.
