Ployzo Member 15 Member For: 13y 11m 16d Posted 27/06/11 11:57 AM Share Posted 27/06/11 11:57 AM Hi Therejust wondering if you guys can help me out, I am about to install a PWR Trans cooler to my BA.I have read on a number of posts that you guys bypass the radiator altogether and just use the trans coolermy question is what are the pro's and con's of bypassing the radiator and not attaching the trans cooler thru the radiator??If you can help me out with this it would be appreciated.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/75536-pwr-trans-cooler-bypass-radiator-or-not/ Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 5m 12d Gender: Male Posted 28/06/11 03:19 AM Share Posted 28/06/11 03:19 AM by bypassing the radiator you won't get coolant in your gearbox, but it might take a little longer for your gearbox oil to reach temp.I'm about to do this with the 6sp auto. Link to comment https://www.fordxr6turbo.com/forum/topic/75536-pwr-trans-cooler-bypass-radiator-or-not/#findComment-1118270 Share on other sites More sharing options...
Ployzo Member 15 Member For: 13y 11m 16d Posted 01/07/11 12:55 AM Author Share Posted 01/07/11 12:55 AM On 28/06/2011 at 3:19 AM, JC807 said: by bypassing the radiator you won't get coolant in your gearbox, but it might take a little longer for your gearbox oil to reach temp.I'm about to do this with the 6sp auto.Thanks for your reply JC, I will have a crack this weekend and install it.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/75536-pwr-trans-cooler-bypass-radiator-or-not/#findComment-1119102 Share on other sites More sharing options...
jasfg Donating Members 61 Member For: 14y 20d Gender: Male Location: frankston Posted 07/07/11 10:34 PM Share Posted 07/07/11 10:34 PM On 01/07/2011 at 12:55 AM, Ployzo said: Thanks for your reply JC, I will have a crack this weekend and install it.Cheersanyupdates? Link to comment https://www.fordxr6turbo.com/forum/topic/75536-pwr-trans-cooler-bypass-radiator-or-not/#findComment-1121071 Share on other sites More sharing options...
Ployzo Member 15 Member For: 13y 11m 16d Posted 11/07/11 12:05 AM Author Share Posted 11/07/11 12:05 AM On 07/07/2011 at 10:34 PM, jasfg said: anyupdates?Yes it all went well, I put it behind my drivers side fog light with a thermo fan and I did bypass the radiator.... Link to comment https://www.fordxr6turbo.com/forum/topic/75536-pwr-trans-cooler-bypass-radiator-or-not/#findComment-1121918 Share on other sites More sharing options...
