Blow-By Help
sambo_xr6t
  • Member For: 15y 6m 3d
hey guys um im looking at buying a bottom end as I shot the rod threw my block the end im buying has had blow-by I only need the bottom end so I can take my motor in to be built there shoulnt be an issue using this bottom end if it gets bored etc ? cheers again you guys are all ways so helpful
  • Member For: 21y 5m 12d
So when you threw a rod you damaged the bottom end as well? If you're buying a new block and fitting the bottom end you bought to it then it should be fine, if what you bought is ok. What year engine is it? If you're rebuilding an engine then you may as well use forged components rather than oem parts.
Benny
