  • Suspended
  • Member For: 16y 8m 26d
I started to do it not sure if I will finish or just wack the leaf springs back in, depends up long I can put up with driving around a 2ltr vitara, just hate tramping last time was at the track felt like the back end was about to fall off
heres my pics so far
I made up the rod ends saved myself $55 each(need 10) and made up the brackets for the diff and front mount to the chassis. I bolted it upto the stock holes that the front hanger brack bolts to. should be mostly bolt on with a bit of welding to the diff and bit for the shock mounts and panard rod. have to cut the old spring mount off the diff also
pics are a bit average
https://www.fordxr6turbo.com/forum/topic/75240-4-link/#findComment-1112613
  • Suspended
also making a custom wood tray
for the rod ends I used landcruiser leaf spring bushes and turned them down. they were cheapest
just have to get the tubing for the bars, will be made out of inch od and threaded 3/4 inside left and right for adjusting on the rod ends. was gona go 4130 tubing but prob a bit over kill
Edited by orangeute338
https://www.fordxr6turbo.com/forum/topic/75240-4-link/#findComment-1112707
  • Suspended
yeah there $52.5 each so that's $500+ just for rod ends, I just made them myself on the cnc lathe and mill cost me $50 for the bushes, I cut out the brackets myself on the cnc mill also. I copied them from the pics off there site and asked a few questions about the sizes and went from there. they also charge $30per m for the tubing but I can get it for $60 for 6m which will do the 4 bars(500mm each) and panard rod(1200mm) and then some for whateva other projects I have on the go;)
I pulled the fuel tank out tonight so I can measure the width of the brackets on the chassis so can cut the spring hangers off now and weld the brackets to the diff. oh need to get the axles out though dont want to get heat into them when welding on the brackets
https://www.fordxr6turbo.com/forum/topic/75240-4-link/#findComment-1112747
  • 3 weeks later...
  • 1 month later...
