  • Member For: 18y 7m 2d
even with only an extra 25kw, as said the extra 100nm of torque should make it worth while, if I can find someone at ford to flash it.
rbjet, good to hear it can and has been done, and worked well
anyone know of someone at ford that would be willing to do this?
  • Replies 26
  • Member For: 17y 1m 27d
No way would ford touch this with a ten foot pole.
Bringing in a car off the street were they don't have a clue what it's life's been like.
I understand ford wouldnt want to do it, as they are supposed to only load the latest tune to match the vin number, but what would it have to do with the history of the car??
  • Im the one and only
  • Member For: 20y 4m 9d
Had a mate as a ford techy and we were doing this years ago.Cheap $50 upgrade over your night time service. :pleasantry:
  • Banned
  • Banned
  • Member For: 14y 8m 5d
You're tighter than 2 coats of paint ! I bet you give out homing pigeons as birthday presents ?
Edited by rab
  • Member For: 17y 11m 9d
If your car has a 6 speed auto transmission or has DSC...forget about it. It will NOT work.
The transmission control module (TCM) in a XR6 turbo is different to a TCM in a FPV. By loading a FPV tune, the transmission will go into limp-home-mode -- indicated by the flashing "D" on the cluster.
If your car has DSC, your cluster will stay lit up like a christmas tree. Since none of the BA/BF FPVs came with DSC, by flashing a FPV tune into a car with DSC, the software on the ABS module, will no longer communicate with the PCM. It will disable traction control and DSC.
Also, like others have already said, the oil light on the cluster will stay lit up (unless you install an oil pressure transducer in place of the standard oil pressure switch).
  • 2 months later...
  • Bronze Donating Members
  • Member For: 13y 9m 20d
this is called tear tagging... you need the tear tag number off an f6 typhoon and IDS software... after reprogramming abs module needs to be flashed also then no lights will be on bar oil pressure light..... phooned is correct (y)
Edited by bionicxr6t05
