  • Member For: 14y 3m 13d
Spoke with a mate that works for Bursons, another alternative that he was recently informed of was using a Nulon Synth with Lubegard Platinum additive.
Lubegard have a chart (doesn't include Aus model cars) which states the factory fluid, and replacement fluid + suitable additive required, as well as the car and transmission type.
Only problem I see, is various cars running the 6HP26, are using slightly different fluids.
I don't like the idea of running something that's obviously not suited (hence why it needs an additive).
Just though I'd post it up as a reference anyway though
http://www.lubegard.com/~/C-113/LUBEGARD+Platinum+Universal+ATF+Protectant
http://www.lubegard.com/pdfs/downloads/LubegardATFConversionBook.pdf
  • Member For: 15y 8m
Gulf Western sounds like an alternative, time will tell
But stay away from Nulon and Penrite, especially Penrite as I've had trans flare issues when I used its SIN ATF
  • Member For: 14y 6m 12d
Ninja, so what do you have in yours atm? Your saying ran SIN ATF and had flare issues (on shift? 3-4th??) and then flushed it out with replacement and all came good? Genuine $$$ stuff? Transmax Z or SynTran Gulf western?
Sounds like you've had what I've got, and a fluid change can possibly be the fix..........so hoping. haha
Stock car? or How much power? Perhaps this makes the difference, Ie I don't think I'd know any better if my car was stock power, it wouldn't be enough to cause the flare/slip.
  • RNS10S
  • Member For: 18y 8m 7d
  On 24/06/2011 at 12:22 AM, Spoony said:
Stock car? or How much power? Perhaps this makes the difference.
These are my thought aswell, My BF MK 2 has over 350 rwkw and almost 100,000 klms. I am now wanting to flush the tranny and would like to know for higher hp and torque applications should we be using a better fluid. This is in now way a means of finding a cheaper fluid as I have already been quoted $450.00 for a flush, filter and 10 ltrs of genuine zf lifeguard fluid which is very acceptable. I only use amsoil oils and fluid and really like their product but dont know if I should try their Transmission fluid. Has anyone used the amsoil ATL fluid in a zf? Your thoughts or info would be much appreciated.
George
Edited by rednose
