  • Member For: 15y 4m 6d
If you drive it very calmly and dont thrash the tits off it too often then on stock power it probably would go for a good 150,000 before signs of slipping etc. But if your buying a 6T then most likely your gonna give it a bit of stick and use the engine to its potential so the never service thing is a bit crap really.
  • Here since the start...
  • Member For: 22y 28d
Do you really want to wait until it starts playing up before changing the oil?
I'd rather be proactive with it than reactive.
  • Member For: 14y 4m 14d
I agree, scheduled servicing/preventative maintenance is there to try and prevent problems, if you wait til they arise it may end up costing you alot more.
Even stock, driving sedate, the zf is tuned with a fair bit of clutch slip to make it smooth, so that will contaminate oil and break it down. Towing adds extra load and heat too.
It's just like waiting for the oil light to come on before changing your engine oil.
Also while in there changing the heat exchanger seems to be a good idea too.
  • 5 months later...
  • Member For: 12y 9m 24d
Hi All
Just going through the process of looking to service my ZF.
Ive been old oil is $34.75 plus GST a litre and that I need 10 plus filter and pan if needed
Question is...
Does 08 FG have plastic or metal pan?
How much is Pan kit
How much is the Filter?
Any help will be appreicated
Cheers
  • Member For: 14y 4m 6d
I thought 20L is required for a full flush?
I have the metal pan so I can just change the filter and oil next time.
There is lots of info on here with most of the questions answered.
  • RNS10S
  • Member For: 18y 9m 7d
When I flushed mine it took 13L, dumped oil by removing pan, changed filter and refitted pan, filled with oil and replaced heat exchanger but left return pipe off, started car and kept pumping oil into box. As soon as we could see clean oil coming out of the heat exchanger we turned off the car, reconnected heat exchanger and topped up. We then test drove the car, rechecked the oil level.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 22d
fg has steel pan late bf2 had them
filter kit can be had for 90 bucks has gaskit and filter
oil prices are all over the place as cheap as $180 for 20L up to near on $500 for 20L a full flush will do 18ltrs approx
