qik1 Silver Donating Members 2,720 Member For: 16y 9m 24d Gender: Male Location: Loitering in SEQ Posted 11/11/12 10:35 PM Author Share Posted 11/11/12 10:35 PM Haha I wish, it's immobilised at the moment, it's minus an exhaust and gearbox Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 4m 9d Gender: Male Location: Far north queensland Posted 11/11/12 11:40 PM Share Posted 11/11/12 11:40 PM Have a good one anyway bud Link to comment Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 16y 9m 24d Gender: Male Location: Loitering in SEQ Posted 16/11/12 08:41 AM Author Share Posted 16/11/12 08:41 AM The big girls in abit of a mess but all in the name of progress. The shifter there hence the strip down so when the box turns up its just a matter of box up & go Link to comment Share on other sites More sharing options...
WHITER33 Member 25 Member For: 14y 1d Posted 18/11/12 12:53 AM Share Posted 18/11/12 12:53 AM Sorry cant really comment mate. Id try riphsv he's been running a c4 with good results for a while so probably be better to ask than meI just used Transmax Z again. If I had my time over I would have gone with a glide over the C4 as I dont know it this will be up to the task anymore.Currently pushing 475rwkw thru it at 24psi. The box would be lucky to have done 1000ks and already needed to give it a freshen up and it burnt out the clutches Link to comment Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 16y 9m 24d Gender: Male Location: Loitering in SEQ Posted 18/11/12 04:09 AM Author Share Posted 18/11/12 04:09 AM Did ya get a hold of riphsv (Ben) because he's had a good run with his c4. Its made good power & run 10.2 so has been proven. Its not so much the boxes fault but rather the parts used more than likely, anything built the right way can handle it 1 Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 8m 10d Gender: Male Location: south east suburbs Posted 18/11/12 04:46 AM Share Posted 18/11/12 04:46 AM (edited) I just used Transmax Z again. If I had my time over I would have gone with a glide over the C4 as I dont know it this will be up to the task anymore.Currently pushing 475rwkw thru it at 24psi. The box would be lucky to have done 1000ks and already needed to give it a freshen up and it burnt out the clutchesIf its burnt out the clutches its obviously slipping through the gears, valve body issue perhaps?, pressure problem?My Btr 4 speeds clutches were not far off new when it was inspected after 4 yrs. Edited 18/11/12 04:48 AM by xr6t_ute Link to comment Share on other sites More sharing options...
WHITER33 Member 25 Member For: 14y 1d Posted 18/11/12 07:03 AM Share Posted 18/11/12 07:03 AM This is what was in the box when first builtBillet Transbrake Reverse Shift Valve BodyVasco + 26 Spline Input ShaftRoller Bearings ThroughoutRaybestos Bands and ClutchesSpecial Heat Treated Race Steels High GearBillet Race ServoModified High Gear Drum for High RPMNew Billet 4 Pinion Planetary (New Billet Gears with Needle Bearing Thrust)New Rear Servo PistonNew Sprag AssemblyRace Modified Lubrication Oiling SystemB&M Alloy pan with Hi-Flow Torqueflite FilterAN-6 FittingsDid ya get a hold of riphsv (Ben) because he's had a good run with his c4. Its made good power & run 10.2 so has been proven. Its not so much the boxes fault but rather the parts used more than likely, anything built the right way can handle itNot as yet but will send him a pm Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 8m 10d Gender: Male Location: south east suburbs Posted 18/11/12 07:09 AM Share Posted 18/11/12 07:09 AM That's what they say, is that really in it? Link to comment Share on other sites More sharing options...
WHITER33 Member 25 Member For: 14y 1d Posted 18/11/12 07:26 AM Share Posted 18/11/12 07:26 AM Sorry to spam this thread That's what they say, is that really in it?I hope so as it was built by someone whos name I have see on here before.I was told when it was fixed here in tassie that it was full of good bits.Just dont know why it would slip unless it wasnt setup correctly. It worked perfect on the dyno with over 50 pulls at 400+rwkwThe first bit of spirited driving on the street it died. Its not like it was loaded up much as it would lose traction coming on boost in every gear. Link to comment Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 8m 10d Gender: Male Location: south east suburbs Posted 18/11/12 07:28 AM Share Posted 18/11/12 07:28 AM Maybe it got too hot on the dyno... Heat is the major destroyer of transmissions Link to comment Share on other sites More sharing options...
