qik1 Silver Donating Members 2,720 Member For: 17y 1m 12d Gender: Male Location: Loitering in SEQ Posted 30/06/12 12:18 PM Author Share Posted 30/06/12 12:18 PM we've got a month now so plenty of time to sought any fidly bits or anything that decides to be diffucult. That & plenty of time to add things to the list. Now that we bring it up we might have something very special real soon (but im not telling just yet 2 Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261343 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 23d Gender: Male Posted 30/06/12 01:56 PM Share Posted 30/06/12 01:56 PM On 30/06/2012 at 10:04 AM, qik1 said: The std torque settings are at 85nm & hence why they still lift, we were retorueing to 105 & it never lifted again with the arp bolts which saw up to 31psi.Theres nothing secret about the headgasket I just dont know a whole lot about it but it does have the orings built into the gasket. The only head gasket options in Australia for this engine are :standard Ford MLSPermaseal MLSCopper with block or head O ringed and 3bond sealant.So whats this one with the O ring build into it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261360 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 1m 12d Gender: Male Location: Loitering in SEQ Posted 30/06/12 06:12 PM Author Share Posted 30/06/12 06:12 PM Its a new option that atomic are trialing in mine. Its been put in another engine that ran some impressive strip times (not an xr body) but wanted to try it in a high boost, high hp engne to make sure its the goods before it becomes a common item. that's about the long and short of what I know about it & the reason its not common knowledge was they wanted to trial it first. Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261377 Share on other sites More sharing options...
tray_182005 Member 1,226 Member For: 15y 10m 15d Gender: Male Location: Wee Waa/NSW Posted 01/07/12 01:28 AM Share Posted 01/07/12 01:28 AM I run the copper gasket with the o ring and 14 mm arp studs . Not sure of the torque but the head still lifted a bit . But theres nothing wrong with see a bit of water spraying out . John u arse MSG me to goodies lol Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261428 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 1m 12d Gender: Male Location: Loitering in SEQ Posted 01/07/12 01:52 AM Author Share Posted 01/07/12 01:52 AM The only reason it would of lifted is that its not torqued down hard enough cause you've seen about the same boost we did using 12'sPossibly unevenly torqued or after repeated high hp runs they do need to be checked and retensioned Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261437 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 4d Gender: Male Location: Zombie Birdhouse Posted 01/07/12 02:42 AM Share Posted 01/07/12 02:42 AM Looks factory under the bonnet This is IMO the finest all round specimen of a T and full credit to all involved over the years.John you must be bleeding from either the arse or forehead ( courtesy of the frying pan)Get a suite of proper pro pics done inside and outAwesome car' 1 Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261446 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 23d Gender: Male Posted 01/07/12 03:43 AM Share Posted 01/07/12 03:43 AM (edited) Its integrity of the combustion zone that is most important. In that video where steam goes thru the exhaust the combustion Zone is breached and the hardest to solve.If it is leaking out of the water jackets and but not getting into the combustion zone then that can be dealt with.In some other high hp per cubic inch motors I have seen the head and block water jackets completely welded up and external flow lines installed.Hope this Atomic head gasket works out.But on the other hand it might not because it might not be the gasket but strength of the block and head and how it is bolted up that determines whether a solution can be found.My Alloy Yella Terra Head on my turbo 202 was cast with a thicker deck to help with sealing the combustion chamber and with a copper head gasket , o ring block and stock diameter size head studs around 10mm, never had head gasket problems with 500+rwhp. Edited 01/07/12 03:49 AM by turbotrana 1 Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261455 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 1m 12d Gender: Male Location: Loitering in SEQ Posted 01/07/12 05:27 AM Author Share Posted 01/07/12 05:27 AM (edited) when steam came out the exhaust it actually broke/snapped headbolts.As far as the new gasket I guess only time will tell either wayThanks as always Jules, when its done this time round the bay should be the best it has been Edited 01/07/12 05:32 AM by qik1 Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261481 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 23d Gender: Male Posted 01/07/12 07:24 AM Share Posted 01/07/12 07:24 AM When you did your steam clean what brand and size stud were you using? Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261506 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 1m 12d Gender: Male Location: Loitering in SEQ Posted 01/07/12 08:28 AM Author Share Posted 01/07/12 08:28 AM they were a atomic sourced tool steel studs &12mm. They were from the very first batch that came through im pretty sure.I had the arp studs & had the head lift at low 20 psi (happened to me twice on two different sets) where they were torqued to 85nm but dialed them down to 105nm & didnt have them lift when we went over 30psi and close to 900hp. didnt get a chance to go any further as we changed to the new style and after two session I think it was this happened but they did see big hp a few times, still not what you would expect.When it was all stripped down there were indents on the head where the bolt washer goes so there is more to our story than just a set of bolts snapping Link to comment https://www.fordxr6turbo.com/forum/topic/75138-fpt-6boost-go-735-plus-kw-still-climbing/page/31/#findComment-1261531 Share on other sites More sharing options...
