kane Member 5 Member For: 13y 9m 14d Posted 30/05/11 02:26 AM Share Posted 30/05/11 02:26 AM I have an '03 XR6T with premium sound and recently noticed a laqck of bass. I checked for power at the sub with a test light and there is nothing, no9 power at all to the subLooked through all the fuses and are all good, I actually couldnt find a seperate fuse for the sub but all fuses are good.I even resorted to the owners manual but still nothing.Everything else seems to work fine as it should just no subwoofer. any help would be greatly appreciated.Kane Link to comment Share on other sites More sharing options...
Pete A Member 442 Member For: 15y 11m 16d Gender: Male Location: Castle Hill NSW Posted 30/05/11 02:46 AM Share Posted 30/05/11 02:46 AM 1. I think there is a separate sub connector on the back of the power unit in the dash. There was in the earlier Premium systems. I have known these to be left off or drop out. This will cause the problem.2. Put an ohm meter across the sub terminals and check you can hear a "click" when you touch the probes. This puts 1.5Volts DC across the terminals and prooves that the subbie is not open circuit. You should read low impedance and hear the "click" and the meter should show almost short circuit. Other than that it could be something in the wiring or the power unit is stuffed.Good luck Link to comment Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 6m 3d Gender: Male Location: adelaide hills- 'race air' central Posted 30/05/11 02:54 AM Share Posted 30/05/11 02:54 AM amp is blown? I think it only powers the sub? Link to comment Share on other sites More sharing options...
kane Member 5 Member For: 13y 9m 14d Posted 30/05/11 11:33 AM Author Share Posted 30/05/11 11:33 AM Thanks Pete a. I shall do those tests tomoro. When you refer to the plug at the back of the unit for the sub, are you refering to the 5/6 plugs along the bottom of the unit or part of the BEM plug at the back? And fordriver I also thought there but there is a harness of around ten wires coming out of the amp. Surely the sub itself does not need all this wiring. Link to comment Share on other sites More sharing options...
knowhereman Donating Members 107 Member For: 13y 1m 23d Gender: Male Location: Torquay, Vic Posted 15/10/11 03:37 AM Share Posted 15/10/11 03:37 AM Found the same problem on the BA MKII I just bought. Found the amp totally missing! Spoke to the dealer they are going to work some out! Yeah right! Has anybody got pics of stock premium amp and connectors? Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 15d Gender: Male Location: Muswellbrook,NSW Posted 15/10/11 04:13 AM Share Posted 15/10/11 04:13 AM behind the carpet on the left hand side (fuel filler side)is where the amp lives. Link to comment Share on other sites More sharing options...
knowhereman Donating Members 107 Member For: 13y 1m 23d Gender: Male Location: Torquay, Vic Posted 15/10/11 06:28 AM Share Posted 15/10/11 06:28 AM Yeah I knew where it was supposed to be, but only the mounting bracket where the amp should be. I found the yellow connector under the parcel shelf but nothing else Link to comment Share on other sites More sharing options...
