Stazza_Brendan Donating Members 686 Member For: 15y 3m 22d Gender: Male Location: Mackay QLD Posted 29/05/11 12:53 AM Share Posted 29/05/11 12:53 AM (edited) So I discovered a nice patch of fluid under my car coming from the pan area of ZF. Jacked up the rear and found it coming from the rear drivers side of the pan where pan meets the box. Did some quick reading and found Jags with the same 6hp26 box gets\ leaks in same position.Plan is to take it to local Ford dealer and replace pan/gasket and change fluid as im prepping for a tune so a fresh box would be a plus.Got a new pan lined up, but what I want to know is if there is any rough price on what Ford charge for service on these so I have a ballpark figure to work on?Is there any other areas it could be leaking from as being on jack stands I couldnt see much but I do know for sure its not leaking out of the wiring connector, that was bone dry.Car is stock tune BF2 ute, obviously out of warranty. Edited 29/05/11 12:54 AM by Stazza_Brendan Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 1m 17d Gender: Male Posted 29/05/11 01:50 AM Share Posted 29/05/11 01:50 AM did you nip up the pan bolts to see if they had loosened? how many km on the car? Link to comment Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 3m 22d Gender: Male Location: Mackay QLD Posted 29/05/11 01:56 AM Author Share Posted 29/05/11 01:56 AM (edited) I need to go get some torx bits, But nothing seemed loose. Even if it is loose bolts needs more fluid put in to replace the unknown quantity that's come out. At 68kon clock. Edited 29/05/11 02:00 AM by Stazza_Brendan Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 4m 25d Gender: Male Location: Mildura Posted 29/05/11 10:34 AM Share Posted 29/05/11 10:34 AM from memory a aftermarket pan kit was around $160 from my local auto shop. Throw sum castrol transmax Z in there, the ZF oil is sh*t. Link to comment Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 3m 22d Gender: Male Location: Mackay QLD Posted 29/05/11 01:05 PM Author Share Posted 29/05/11 01:05 PM Heard some have issues with transmax z. Went and got some torx spanners and went over the pan bolts. A few were a bit loose but nothing major. No seeping now. Will take for a longer drive and recheck next weekend. Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 4m 25d Gender: Male Location: Mildura Posted 30/05/11 12:00 PM Share Posted 30/05/11 12:00 PM I dunno who "some" are, but theres more than just a couple on here who use it... and nearly every ZF that's been built stronger pretty much runs Transmax Z, some cars upto the tune of 600kw.My car felt 300% better in the first 10 seconds of driving... I know it was fine in my car. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 3m 11d Gender: Male Posted 31/05/11 05:27 AM Share Posted 31/05/11 05:27 AM transmax z in my car to , and sweet as. Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 1m 17d Gender: Male Posted 31/05/11 10:12 AM Share Posted 31/05/11 10:12 AM I've asked before, but how did you guys who use Transmax Z flush ALL the old fluid out? I'm keen to give it a go. Link to comment Share on other sites More sharing options...
hardcore Member 92 Member For: 16y 9m 17d Gender: Male Posted 31/05/11 11:07 AM Share Posted 31/05/11 11:07 AM I actually just came on to post this issue with mine. I went away for 2 weeks and car was not driven in that time. I moved it to notice an oil patch in my garage. I got under my car and noticed it was leaking from the same spot as mentioned above. Could not tighten the bolts up any futher with an allen key it just kept slipping. I have since moved my car and it has not leaked for the past 3 days. SHould it sitting there undriven cause this?Ford Dealer has wiped my gearbox out in the past driving into thier workshop and replaced gasket 30 000k's ago.Any suggestions?Sorry to steal your thread also Link to comment Share on other sites More sharing options...
A300srt8 Member 507 Member For: 20y 1m 7d Posted 31/05/11 12:12 PM Share Posted 31/05/11 12:12 PM I have a xtf Zf using castrol fluid and find its a bit sluggish when cold but really firm when hot Link to comment Share on other sites More sharing options...
