  • Moar Powar Babeh
  • Member For: 19y 8m 18d
whats driving the compressor in the 737 apu? a fairly significant fuel air energy conversion in the arse end?
whats driving the compressor wheel in a turbo? the left overs of significant fuel air energy conversion. that happens too cease once the throttle is closed and the compressor surge starts?
not same/same
  • Member For: 16y 6m 19d
True, when the throttle is shut the force spinning the turbo dies down too so the only opposing force to the air from the surge is the momentum of the small impeller of the turbo. Bov's help throttle response on gear changes by letting the surge out so the turbo can keep spinning.
  • Member For: 16y 2d
I'm not saying don't make your car flutter nor do I care if you do, just pointing out the fact the it does damage the turbo,
as for a fairly significant fuel air energy conversion you can be the judge,
an APU in a 737-400 is basically a GT60 sized turbo with a combustion chamber coupled to the turbine housing and a small gearbox on the compressor housing, much like the home made "jet engines" on youtube. They make approx 420 hp and burn around 350 kg of fuel per hour, about the same as a 420hp xr6t would if you held it flat-out in 6th for an hour, they are a "starter motor" for the main engines and work the same as a turbo which is why they have surge valves (BOV"s) on them.
  • Member For: 14y 10m 21d
  • Gender: Not Telling
Some time back I did do some research on the above, and from memory the evidence suggested that a bov was crucial for turbo durability, but there was no evidence that could categorically state to what extent durability was compromised. But logic suggests that a turbine wheel spinning one way and then back pressurised air inturn creating forces trying to spin the wheel in the opposite direction, surely creates stresses on fins, shaft and bearings. Now as I said, this is from memory so please correct me if I am not understanding this correctly, Cheers
Edited by Impellor
