Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 15d Gender: Male Location: Perth Posted 25/05/11 06:49 AM Share Posted 25/05/11 06:49 AM Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1108876 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 18d Gender: Male Location: Vic Posted 25/05/11 07:00 AM Share Posted 25/05/11 07:00 AM On 25/05/2011 at 5:20 AM, Dillz said: Let unfiltered air in!? Sounds like a good idea... The bov has it's own filter, which will stop any large debris going in. You should clean and re-oil your bov filter every 5000kms to keep it running at it's best. Otherwise you will lose performance and use more fuel. Ford genuine floor mays will also help your car accelerate. Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1108888 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 12d Gender: Male Location: Melbourne Posted 25/05/11 07:54 AM Share Posted 25/05/11 07:54 AM What BOV you talkin bout? I've never seen a BOV with a filter. Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1108916 Share on other sites More sharing options...
falcon04 Member 20 Member For: 14y 4m 27d Posted 25/05/11 08:08 AM Author Share Posted 25/05/11 08:08 AM cheers for that... a little crap being spun along the way I think Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1108923 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 15d Gender: Male Location: Perth Posted 25/05/11 08:54 AM Share Posted 25/05/11 08:54 AM SRS Answer, As loose as you can without it crackin open on idle. The looser it is the faster it will open to vent boost. If you clamp it down hard it will only open on full boost throttle slammed conditions.Turbosmart go into the setup in quite a bit of detail on the instruction which you can download from http://www.turbosmartonline.com/index.php?s=downloads Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1108956 Share on other sites More sharing options...
Cheaty McCheats Totally not a Cop Donating Members 821 Member For: 14y 4m 13d Gender: Male Location: Melbourne Posted 07/06/11 11:50 AM Share Posted 07/06/11 11:50 AM I have mine as tight as possible, sounds like a fully hektik VL turbo in the cold air when I give it squirts. Full boost it cracks like a whip. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1112480 Share on other sites More sharing options...
axel28 Member 8 Member For: 14y 3m 17d Posted 11/06/11 08:21 AM Share Posted 11/06/11 08:21 AM hi I have this same bov and is wonder if I hooked it up right is air meant to blow out of the trumpet on idle my be a dumb question but I'm dumb Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1113392 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 18d Gender: Male Location: Vic Posted 11/06/11 09:47 AM Share Posted 11/06/11 09:47 AM It should be sealed at idle, no air should be flowing through it! That will be blowing boost out. Throw a pic up of you have it setup. Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1113417 Share on other sites More sharing options...
axel28 Member 8 Member For: 14y 3m 17d Posted 12/06/11 02:05 AM Share Posted 12/06/11 02:05 AM On 11/06/2011 at 9:47 AM, henz said: It should be sealed at idle, no air should be flowing through it! That will be blowing boost out. Throw a pic up of you have it setup. Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1113580 Share on other sites More sharing options...
axel28 Member 8 Member For: 14y 3m 17d Posted 13/06/11 08:05 AM Share Posted 13/06/11 08:05 AM is that set up right? its a fg by the way Link to comment https://www.fordxr6turbo.com/forum/topic/75017-is-it-best-to-have-bov-loose-or-tight/page/2/#findComment-1113901 Share on other sites More sharing options...
