ptharris New Member 13 Member For: 13y 10m Posted 24/05/11 07:08 AM Share Posted 24/05/11 07:08 AM (edited) Hi guysI have a weird condition in 4th gear say from 1500rpm to 3000rpm at WOT, whilst logging you can see the ETC (electronic throttle) opening then closing, opening closing etc. You can also feel it in car obviouslyOnly does it in 4th gear between 1500-3000rpm at WOT all other gears are good.Torque management is disabled2005 BA MKII XR6 Turbo4 speed autoSTD carTune to 8 psi and full remap on dynapac dyno, using vcm suiteAny ideas, have log but cant attach it here for some reason Edited 24/05/11 07:08 AM by ptharris Link to comment Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 1m 15d Posted 24/05/11 07:22 AM Share Posted 24/05/11 07:22 AM Still sounds like torque control to me.... Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 11d Gender: Male Location: Perth Posted 24/05/11 07:27 AM Share Posted 24/05/11 07:27 AM +1, whats your max engine torque set at? Link to comment Share on other sites More sharing options...
ptharris New Member 13 Member For: 13y 10m Posted 24/05/11 07:41 AM Author Share Posted 24/05/11 07:41 AM (edited) I also believe its torque controlMax is set at 525, didnt touch that table. Tried logging engine deliverd torque with HPT VCM, but didnt logTuned today to 247kw on dynopac, I was very happy with results, stock was 203kw. Just looked at the dyno reading, Im hitting 600nm of torque at 2600rpm, dont know if this helps with that tableDidnt notice this till I road tested itHiddeous, I have emailed you my tune and logCheersPhil+1, whats your max engine torque set at? Edited 24/05/11 07:50 AM by ptharris Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 2m 16d Gender: Male Location: North West Hot Hell,VIC Posted 24/05/11 07:58 AM Share Posted 24/05/11 07:58 AM Mines set at 752 you could try that and see how it logges. Link to comment Share on other sites More sharing options...
ptharris New Member 13 Member For: 13y 10m Posted 24/05/11 08:15 AM Author Share Posted 24/05/11 08:15 AM This table?Mines set at 752 you could try that and see how it logges. Link to comment Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 2m 10d Posted 24/05/11 10:01 AM Share Posted 24/05/11 10:01 AM You only need to log your Torque Source, Fuel Source and Spark Source during the condition - and the answer will be right there in front of you.Then simply adjust the RPM to use ETC for Torque Reduction table. I have no idea if this table exists in HPT Ford tuning, but that will be most if not all of your answer. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 7d Gender: Male Location: @ my laptop Posted 24/05/11 10:10 AM Share Posted 24/05/11 10:10 AM Yes that table does exist Link to comment Share on other sites More sharing options...
ptharris New Member 13 Member For: 13y 10m Posted 24/05/11 10:24 AM Author Share Posted 24/05/11 10:24 AM ETC Torq managment is set to all zerosTorque Source, Fuel Source and Spark Source is not avaliable in HPT (that im aware of, maybe named different)Ive logged it and its definitely throttle plate closing, then opening, then closing. So definitely torque reductionYou only need to log your Torque Source, Fuel Source and Spark Source during the condition - and the answer will be right there in front of you.Then simply adjust the RPM to use ETC for Torque Reduction table. I have no idea if this table exists in HPT Ford tuning, but that will be most if not all of your answer. Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 2m 16d Gender: Male Location: North West Hot Hell,VIC Posted 24/05/11 11:51 AM Share Posted 24/05/11 11:51 AM No the section was under Trans then Torqe Management and the figure I gave was 752ftlb or in metric 1020Nm. Link to comment Share on other sites More sharing options...
