Dyno Question
plaine
  • Member For: 14y 1m 4d
I have a 2010 fg xr6 t ute and I had it originally tuned at CV and made 265.8kw with just a tune and now ive put a PW stage 2 cooler kit on it and was curious if the cooler would make any differece, so I put it on a dyno today to check before I get new injectors and a re tune from cv.
It was the same make of dyno and it only made 253.8kw and they ran it in 3rd gear for that figure.
Do they normally dyno run them in 3rd gear??
cheers
  • Member For: 14y 9m 28d
Basically you won't get same reading on different dynos. There are a lot of variables that go into getting the end figure which includes the weather on the day. And they can run in 3rd but you should always compare like results so if it was run in 4th then you want to always use that gear.
