NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 3m 5d Gender: Male Location: Perth, WA Posted 21/05/11 01:57 PM Share Posted 21/05/11 01:57 PM Hey all,Just have a quick question. My BA XR6T has a really annoying 'surging' feeling when driving her cold. Until about 5 minutes into a drive, or around 1/4 engine temp she just hesitates during acceleration.She doesn't cough or splutter but just really hesitates... Even with a full tank of fuel.Have just done the air filter, brand new NGK spark plugs gapped to 1.1 (running car stock)and brand new ford factory coil packs (all 6) tightened all fittings and hoses. Doing all new coolant and flush tomorrow and oil and oil filter early next week.I'm wondering if this is a fuel system issue? Injectors or fuel pump? Possibly the fuel filter? I think she is due for a new fuel filter pretty shortly, but if that doesn't fix it I'm pretty much out of idea's... Could it be a gearbox issue?It seems when it is at operating temp it is ok - Still a little 'rough' feeling though... Could it be an engine issue? A busted 02 sensor? A shot cat?Thanks guys, I'm pretty lost with this one actually...Cheers! Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/ Share on other sites More sharing options...
KeepLeft Member 240 Member For: 15y 10m 9d Gender: Male Posted 21/05/11 02:47 PM Share Posted 21/05/11 02:47 PM Pretty sure this is part of the factory ford tuning. A couple of tuners on here have managed to fix it up with a retune. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1107915 Share on other sites More sharing options...
plcains Member 49 Member For: 14y 10m 17d Posted 21/05/11 03:21 PM Share Posted 21/05/11 03:21 PM I get this in an fg when its real cold outside for the first boost, I've been told its normal. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1107918 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 5d Gender: Male Location: Newcastle Posted 21/05/11 09:31 PM Share Posted 21/05/11 09:31 PM Free factory fitted option in the FG but I'm pretty sure the BA doesn't do it. You'd think if it was a fuel filter, pump or cat issue the car would struggle at WOT. Maybe one of the tuners here might be able to help.Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1107936 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 19d Gender: Male Posted 21/05/11 10:34 PM Share Posted 21/05/11 10:34 PM my bf mk2 does it aswell, let it warm up for a extra 30sec and all sweet. no need to be concerned. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1107945 Share on other sites More sharing options...
Davidxr6t03 Member 58 Member For: 14y 10m 26d Posted 22/05/11 12:25 AM Share Posted 22/05/11 12:25 AM Mine also does it on the Stock Tune, Custom tune no surge what so ever. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1107957 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 6m 2d Gender: Male Location: left right out Posted 22/05/11 06:55 AM Share Posted 22/05/11 06:55 AM I would be replacing the oxy sensor, fairly cheap on e bay, some have a heater element which gets it hot from stone cold, until the exhaust heats up to normal. If the element is stuffed it will give you a dud signal and the computer will overfuel in response. Not to hard to replace , and they dont last forever anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1107997 Share on other sites More sharing options...
Patski Member 23 Member For: 13y 11m 11d Gender: Male Location: Port Macquarie Posted 05/01/12 10:43 AM Share Posted 05/01/12 10:43 AM hi mate did u figure out wat the problem was? im having the same problem but only started after a tune. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1177280 Share on other sites More sharing options...
itsagoanna Member 6 Member For: 13y 5m 16d Gender: Male Posted 06/02/12 04:52 AM Share Posted 06/02/12 04:52 AM I have same problem with my FG turbo...stock tune, vented BOV to air, and replace air box with high flow pod filter system. Surged with and without mods when cold but just went down to ford and told it was not normal and they are suppost to run smooth even when cold. Vehicle is about 2-3 months out of warranty but was told there is a 'grace' period where ford may still cover under warranty or at least cover cost of parts as long as service history etc is sweet (28,000kms on car and for serviced up to 40,000km handbook service....should be sweet). Fingers crossed they fix it for free! (will be putting vehicle back to standard before I give car to them Also trying to get them to fix the ambient temperature sender (in the left hand mirror) as it reads about 6 degrees on a 40 degree day.Will re-post after next week when they've 'had a look'. Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1191821 Share on other sites More sharing options...
itsagoanna Member 6 Member For: 13y 5m 16d Gender: Male Posted 10/03/12 12:48 PM Share Posted 10/03/12 12:48 PM Got Ford to look over my car, before the car went in they were telling me all about this 'grace' period and how it will most likely be covered...None of it was, they did work without me approving it and gave me a nice bill...another story. Apparently they upgraded the computer on it which was suppost to prevent the surge...it did absolutely nothing, and the temperature sender was stuffed and they wanted $80 to change it...I took about 10 steps over to the parts department and the sender costs $15 so I will be putting it in myself. You think they could put in a $15 sensor to keep the customer happy when its a well known problem with these models!I've never understood why a lot of car yards have such bad service when it comes to warranty work and repairs. It certainly does not make you want to deal with them again! Link to comment https://www.fordxr6turbo.com/forum/topic/74971-surge-when-cold/#findComment-1208288 Share on other sites More sharing options...
