AtomiCg6 Donating Members 197 Member For: 14y 3d Posted 01/08/12 08:37 AM Author Share Posted 01/08/12 08:37 AM On 01/08/2012 at 2:04 AM, xr6t_ute said: Could also be vibration making them loose, loctite doesn't work all the time there's another type of glue I can't recall the name off that is good for high temperatures.Type of bolts also used can also be the problem, just one of those things you have to try and see.Yeah vibration comes and goes a lot of the time, over 80k?The thing is after I picked it up, a month or so ago after breaking my bolts from my flex etc, Had it all repaired, On the way home 20mins into my drive the vibes came bak, and then went away, didn't come bak after that, maybe once in the wk.. It's a pretty bad shake, though out the steering drivetrain, over around 85k.. But only on the pedal.. I took it bak to hpf and had noticed the bolts had come loose on the flexpate and the dowels were showing signs of damage, only a wk after being installed... Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1273518 Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 15y 3m 1d Gender: Male Posted 01/08/12 09:57 AM Share Posted 01/08/12 09:57 AM you need to run this with the stock G6E 18" wheels all round and some 245/40/18 mt et's on the backthen bam 145mph people will be like holy crap what the faaarkkkk!! 4 Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1273540 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 9m 23d Gender: Male Location: south east suburbs Posted 01/08/12 10:10 AM Share Posted 01/08/12 10:10 AM Well that may be your problem with the convertor bolts coming loose. Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1273548 Share on other sites More sharing options...
PookeyMaster Donating Members 1,531 Member For: 14y 3m 29d Gender: Male Location: Parramatta, NSW Posted 01/08/12 12:48 PM Share Posted 01/08/12 12:48 PM On 01/08/2012 at 8:22 AM, AtomiCg6 said: If I can run 9.50 and drive the car home, who needs 700kw true?? LolIt's good to see someone with a target that's not a power figure. 3 Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1273601 Share on other sites More sharing options...
stee3 Member 194 Member For: 13y 9m 23d Posted 03/08/12 07:44 AM Share Posted 03/08/12 07:44 AM that's big MPH mate! I recon I have seen this car around Dandenong area wouldnt pick it apart from the exhaust out the back.. Do you have axles in the diff or is it an all standard rear end? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1274227 Share on other sites More sharing options...
ovaxitd Member 49 Member For: 16y 1m 24d Gender: Male Location: Perth SOR Posted 04/08/12 02:31 PM Share Posted 04/08/12 02:31 PM just quietly how the fk are the std brake holding up from 144mph haha... you have discs and pads under there?also have you thought about drilling bolts and getting them wire tied as a daisy chain together to stop them from loosening? Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1274765 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 2m 30d Gender: Male Location: Christchurch, New Zealand Posted 05/08/12 01:57 AM Share Posted 05/08/12 01:57 AM Yea could try lockwiring them together, has anyone done that to a flywheel though. As long as its nice and tight I cant imagine it being a problem. Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1274874 Share on other sites More sharing options...
AtomiCg6 Donating Members 197 Member For: 14y 3d Posted 06/08/12 10:43 AM Author Share Posted 06/08/12 10:43 AM On 03/08/2012 at 7:44 AM, stee3 said: that's big MPH mate! I recon I have seen this car around Dandenong area wouldnt pick it apart from the exhaust out the back.. Do you have axles in the diff or is it an all standard rear end?Yeahh mate Its around dandenong heaps, Turns a few heads driving past Expensive Daewoo and ford dealerships on the hwy lol..The real end just has a truetrack, with billet axles, Not to sure wat else is done to the diff, just waiting for it to blow, then ill do something different Ive had a read of your mods, fukk me broo, wat cars this ?? lol 1 Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1275572 Share on other sites More sharing options...
AtomiCg6 Donating Members 197 Member For: 14y 3d Posted 06/08/12 10:46 AM Author Share Posted 06/08/12 10:46 AM On 04/08/2012 at 2:31 PM, ovaxitd said: just quietly how the fk are the std brake holding up from 144mph haha... you have discs and pads under there?also have you thought about drilling bolts and getting them wire tied as a daisy chain together to stop them from loosening?Brakes stopp amaziing actually, ive got racing pads and dics up front that's all lolI think once we work out why there is so much vibration, and illuminate that's, dont think they will get loose again, weve done everything else I think lol, I will let them know about your suggestion, thanks mate Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1275575 Share on other sites More sharing options...
stee3 Member 194 Member For: 13y 9m 23d Posted 06/08/12 01:08 PM Share Posted 06/08/12 01:08 PM Hey man what sort of flex plate are you using? Have you got an Atomic flexplate? I got one today with my converter so I hope they dont come loose. If they come loose wire lock or tack weld them so they never move. On 06/08/2012 at 10:43 AM, AtomiCg6 said: Yeahh mate Its around dandenong heaps, Turns a few heads driving past Expensive Daewoo and ford dealerships on the hwy lol..The real end just has a truetrack, with billet axles, Not to sure wat else is done to the diff, just waiting for it to blow, then ill do something different Ive had a read of your mods, fukk me broo, wat cars this ?? lolIts just a little BA you wouldnt have seen it around, what was suppost 3 months to build ended up over 12 months.. I should be out and about in a week or 2 if I see you around ill come and say hi to you. After looking at your vidoe are you having trouble building boost on the trans brake? Is your throttle body shutting? You have one really fast car keep up the good work. Link to comment https://www.fordxr6turbo.com/forum/topic/74936-hoping-for-600kw-and-9sec-14-mile-from-my-g6e/page/27/#findComment-1275634 Share on other sites More sharing options...
