ratter Member 6,793 Member For: 19y 1m 3d Gender: Male Location: @ my laptop Posted 17/02/10 10:07 AM Author Share Posted 17/02/10 10:07 AM We have fitted a few of these exhausts and have not had 1 complaint about drone, infact they are probably the quiest aftermarket full exhaust I have heard on these cars.Nizpro were doing on FG's a variable valve on the rear muffler which would allow the 2nd pipe to open after a certain boost level, I have not fitted a FG version to see this Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-982942 Share on other sites More sharing options...
scorsto Member 40 Member For: 16y 8m 28d Posted 17/02/10 10:07 AM Share Posted 17/02/10 10:07 AM On 17/02/2010 at 7:28 AM, MILES said: I've recently been thinking about putting the nizpro 4" exhaust on my car.Current mods are nizpro stage 1 plus, But without the nizpro cat. Didn't wanna put it on because it seemed like a waste if I was gonna buy the whole 4" system anyway. Make about 270rwks atm. Does anyone know what sort of rwkw figure I will get with my current setup, plus the 4" exhaust.Also I've heard that the new nizpro 4" exhaust drones at cruising speeds, is there anyone out there with this sort of exhaust that can say wether this is true or not? Cause I like the quiet system I've got at the moment.1 last thing, Is it true Nizpro are developing an even newer 4"system, similiar to the xforce varex system, to overcome the drone? Has anyone heard of this?Cause I'll be holding out for it if its true.Sorry bout all the questions, but any help would be good. Thanks in advance.All I can say is the Nizpro 4inch is a great piece of gear.I have a BF F6 rspec auto and was concerened like yourself with drone.The exhaust is quiet,does not drone and sounds awesome above 3000 rpm.I had it fitted with rapids V3 ported turbo housing deka 60lb and walbro in tank pump which took the car from 242rwkw to 370rwkw on 16psi.Hope this helpsJim Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-982943 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 6m 5d Gender: Male Location: Melbourne Posted 17/02/10 10:25 AM Share Posted 17/02/10 10:25 AM put the exhuast on, and you will love it. its really good. as the others have said it does not drone. nizpro put alot of testing into this system so it makes a good note, quite at crusing but sounds awesome when you boot it. enjoy it. Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-982959 Share on other sites More sharing options...
F6T Member 93 Member For: 17y 5m 7d Gender: Male Location: Tasmania Posted 17/02/10 10:46 AM Share Posted 17/02/10 10:46 AM On 17/02/2010 at 10:07 AM, scorsto said: All I can say is the Nizpro 4inch is a great piece of gear.I have a BF F6 rspec auto and was concerened like yourself with drone.The exhaust is quiet,does not drone and sounds awesome above 3000 rpm.I had it fitted with rapids V3 ported turbo housing deka 60lb and walbro in tank pump which took the car from 242rwkw to 370rwkw on 16psi.Hope this helpsJimI also have the nizpro 4" system fitted. BA F6 manual. I was hyper sensitive/paranoid that it would drone. All I can say is that I am VERY happy with it. At cruising speed it is surprisingly quiet for it's size and no drone. Just as quiet if not quieter than the stock system. I had the BF perforated tips fitted and would recommend same. It can be a little boomy on cold start up but this goes within the first couple 100 metres. and for a split second on 1st/2nd gear slow take offs but this is a very minor criticism - almost to the point of not worthy of mention.Se sounds awesome - spine tingling in car - when boost comes on. Idle is nice and menacing.Get it fitted right though. Mine vibrated to start with as it was touching in places but this was quickly rectified and 8 months on I have not had one single issue with it notwithstanding that you get a bit of growth in the s/steel when she warms up.Mine is slightly lowered and the exhaust has never fouled on anything like drive/speedhump etc etc. Not once.You will probably need to modify your turbo with the larger flapper and wastegate porting to keep boost levels down. Even with those mods, we couldn't get it to go any lower than 15.5 - 16psi. We couldn't get power any lower than 340rwkw at that. Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-982976 Share on other sites More sharing options...
MILES Donating Members 103 Member For: 17y 1m 23d Gender: Male Location: Townsville Posted 18/02/10 08:26 AM Share Posted 18/02/10 08:26 AM Hey, thanks everyone for the help. I think I'll go for it then. You all sound like happy customers.Can't wait to get it fitted. What other mods do you think I should do to get up around the 350-370rwkw mark? Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-983279 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 26d Gender: Male Location: Townsville Posted 18/02/10 09:08 AM Share Posted 18/02/10 09:08 AM 4inch intake system and maybe turbo flapper mod and actuator. As long as injectors are big enough cant see why it wont get there if it's a B series or F6.May need valve springs depending on year model also. Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-983307 Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 17y 1m 21d Gender: Male Location: Greenvale, Victoria Posted 27/02/10 03:15 PM Share Posted 27/02/10 03:15 PM I have the Nizpro big Zorst. I had it fitted so it would allow mods later on and I wouldn't be restricted.The thing under neath looks like a cannon. Much bigger than youd assume. You can certainly hear it in the car but as some have said the noise on full boost is spine tingling. On idle...make sure all the windows in your house are solid. My kids can here my car from the back of the house. But its not loud, just rumbles. Awsome.If I get the balls to let someone actually drive my car I'd love to hear it from outside.Had it ad Ford a few weeks ago and when they put it on the hoise the whole workshop stopped to have a look at it...they couldnt get over the workmanship of it.Probably overkill for me but the tips sort of look standard until you start it and give it a boot. Then it turns heads.I can't compare it to any cat back or twin system, but id have to recomend it as good gear. I'm after the "sleeper" look and this sort of fits in with that until I open it up. You wont be dissappointed. Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-986247 Share on other sites More sharing options...
stevegong Member 13 Member For: 15y 5m 6d Gender: Male Location: Wollongong Posted 27/02/10 09:20 PM Share Posted 27/02/10 09:20 PM On 17/02/2010 at 10:46 AM, F6T said: It can be a little boomy on cold start up but this goes within the first couple 100 metres. and for a split second on 1st/2nd gear slow take offs but this is a very minor criticism - almost to the point of not worthy of mention.Sorry for my ignorance (im very new to all this), but when you say a split second slow on 1st/2nd, am I understanding it wrong that the car is a split second slower Now on take offs (every time) or just when it worms up ?Thanks for anyone that can clarify in advance. Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-986261 Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 17y 1m 21d Gender: Male Location: Greenvale, Victoria Posted 27/02/10 10:50 PM Share Posted 27/02/10 10:50 PM I think he means its a bit loud for a split second. If anything it will add power to your setup. that's what its mainly for. With forced induction like Turbos, the engine needs to breath, If it doesnt breath it doesnt live, so the more it can breath....get the picture? Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-986268 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1m 3d Gender: Male Location: @ my laptop Posted 27/02/10 10:57 PM Author Share Posted 27/02/10 10:57 PM We have 1 on display in our workshop if anyone wants to look at 1 Link to comment https://www.fordxr6turbo.com/forum/topic/74892-nizpro-exhaust/page/8/#findComment-986271 Share on other sites More sharing options...
