fordom Member 145 Member For: 15y 7m 9d Gender: Male Location: sydney Posted 22/05/11 10:31 AM Share Posted 22/05/11 10:31 AM does this apply to a bf mk 11 aswell? Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1108063 Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 7m 4d Gender: Male Location: Melbourne Posted 22/05/11 12:09 PM Share Posted 22/05/11 12:09 PM Same $10 POS so probably fordham Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1108115 Share on other sites More sharing options...
Gonadman2 Member 140 Member For: 18y 7m 10d Gender: Male Location: Perth - WA Posted 23/05/11 06:35 AM Share Posted 23/05/11 06:35 AM (edited) By reversing the polarity, all you done is 'move' the sound wave 180 degrees either forward or backward. Think of it as increasing or decreasing the time delay on your receiver at home and you're on the right track. A speaker is pistonic in operation, wiring it out of phase will not cause any physical problems to it. Quite often tweeters are wired out of phase due to the passive crossover design that is used already pulling them out of phase. Problems like this usually occur when your 'fully sik' types install full range 6x9 speakers on the parcel shelf and then install a sub down the track. When 2 equal frequency sound waves interact you get boosting or cancelling at that frequency. The same thing happens when you have a twin sub setup, and reverse the polarity on one of the subs.I'm assuming the rear speakers are on the parcel shelf, and are playing full range, and so is the sub. So you getting a lot of cancellation if they are out of phase with each other. Reversing the polarity will bring them back in phase and therefore you should be getting cleaner bass. To test if this is true, you could try reversing the phase on the rear speakers, or just unplugging them altogether. Edited 23/05/11 06:36 AM by Gonadman2 Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1108257 Share on other sites More sharing options...
kink Member 294 Member For: 16y 9m 28d Gender: Male Location: Adelaide Posted 23/05/11 01:55 PM Share Posted 23/05/11 01:55 PM FG has speakers in the rear doors... Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1108435 Share on other sites More sharing options...
Pete A Member 442 Member For: 16y 5m 30d Gender: Male Location: Castle Hill NSW Posted 24/05/11 02:14 AM Share Posted 24/05/11 02:14 AM On 23/05/2011 at 6:35 AM, Gonadman2 said: By reversing the polarity, all you done is 'move' the sound wave 180 degrees either forward or backward. Think of it as increasing or decreasing the time delay on your receiver at home and you're on the right track. A speaker is pistonic in operation, wiring it out of phase will not cause any physical problems to it. Quite often tweeters are wired out of phase due to the passive crossover design that is used already pulling them out of phase. Problems like this usually occur when your 'fully sik' types install full range 6x9 speakers on the parcel shelf and then install a sub down the track. When 2 equal frequency sound waves interact you get boosting or cancelling at that frequency. The same thing happens when you have a twin sub setup, and reverse the polarity on one of the subs.I'm assuming the rear speakers are on the parcel shelf, and are playing full range, and so is the sub. So you getting a lot of cancellation if they are out of phase with each other. Reversing the polarity will bring them back in phase and therefore you should be getting cleaner bass. To test if this is true, you could try reversing the phase on the rear speakers, or just unplugging them altogether.Essentially correct. The crossover of the lower frequencies in the "other speakers is an important issue. But they are full-range (except the tweeters) The Subbie should not be out of phase with the other full range speakers. The same signal coming from 2 different speakers out of phase will cancel each other or reduce the recoverable bass component. I would not have thought that this is a faulty install by Ford. If you consider your home theatre, it's the same thing. When you add a subbie, the amp changes the low frequency response to the other speakers and the subbie crossover point can be changed to suit the other speakers. Sounds like an interesting thing to try though I must admit! I think the Premium system I had on the BAII was far better than the FG, but one of the reasons was the moving of the speakers from the parcel shelf to the rear doors. That was done so rear seat passengers were not "blasted" when the sound was up a bit high. Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1108499 Share on other sites More sharing options...
Timmy-XR6T Silver Donating Members 179 Member For: 15y 9m 20d Gender: Male Location: Sydney, Inner South Posted 11/06/11 09:19 AM Share Posted 11/06/11 09:19 AM im heading out to the car now, got to give this a try - ive been very dissapointed by the (lack off) performance with the premium sound so hopefully this adds some bang for the buck Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1113408 Share on other sites More sharing options...
dre Resident idiot. Donating Members 2,068 Member For: 14y 8m 13d Gender: Male Location: Melbourne Posted 11/06/11 01:24 PM Share Posted 11/06/11 01:24 PM A better amp and a different 8" sub is the answer. Changing polarity doesn't do anything. Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1113480 Share on other sites More sharing options...
LEEXR6T Donating Members 91 Member For: 20y 1m 19d Gender: Male Posted 12/06/11 12:48 AM Share Posted 12/06/11 12:48 AM Just tried to switch the wires around to see if it makes a difference....I removed the clip insert in the plastic that hold the clips and was unable to removes the wires without pulling the wires from connectors, am I doing something wrong? Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1113560 Share on other sites More sharing options...
Timmy-XR6T Silver Donating Members 179 Member For: 15y 9m 20d Gender: Male Location: Sydney, Inner South Posted 12/06/11 01:32 AM Share Posted 12/06/11 01:32 AM I had the same problem - removed the latch and couldnt get the wires out - got the sh*ts with it last night and will try again today - if any one has any tricks to getting them out let us know Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1113571 Share on other sites More sharing options...
XRTFG6 Member 97 Member For: 14y 3m 23d Gender: Male Posted 12/06/11 03:47 AM Share Posted 12/06/11 03:47 AM You need to use a thin screw driver and lift the small clips inside holding the plugs in (I did mine opposite side to wires) BUT don't waist your time dose nothing I was testing the same song changing the wires over from one side to the other and found it did jack s#%t I agree with dre you want better bass by a new sub Link to comment https://www.fordxr6turbo.com/forum/topic/74886-fg-sub-fix/page/2/#findComment-1113598 Share on other sites More sharing options...
