  • Member For: 13y 3m 17d
Can any one clarify what side is the blue wire on the white plug from factory, is it on the right or left side?
Mine is on the right side and sounds good, but I only bought my car last week and was wondering if it had already been swapped over from previous owner.
Thanks Jstplyn. That confirms the orginal owner had already swapped the wires over.
As when I swapped them over the Sound was awful, no bass and was distorted!
  • 3 weeks later...
  • New Member
  • Member For: 11y 6m 5d
thanks for this guys made a huge diffenence in mine I didnt pull the hole parcel shelf out as no need just folded the seats down uncliped the the front of parcel shelf and uncliped the front of the under parcel shelf panel at the front and just worked thru that hole took all of 5 mins to do
  • Turbo Noob
  • Member For: 12y 8m 20d
Just installed the jaycar response 8" sub. Was pretty easy except that I didn't have the star pattern wrench (to take out the anchor for baby seat) and had to borrow one. Definitely need to put some dynamat or something on the shelf but is a cheap improvement from factory. Only $40. A bit more punch and can hear lower frequencies.
Ant
  • 2 weeks later...
  • 1 month later...
  • Member For: 11y 9m 27d
Thanks for sharing this tip, just done the change and definately a good improvement. Would changing the factory sub for an after market one (same 150 RMS rating), while still using the factory amp to make much difference? Was looking at the pioneer 150 RMS shallow mount sub?
