Paulie2256 Donating Members 7,441 Member For: 16y 3m 17d Gender: Male Location: SE Melbourne Posted 17/05/11 03:30 AM Share Posted 17/05/11 03:30 AM Im guessing because after the thrashing the valve springs become really soft and are having trouble keeping the exhaust valves closed on combustion. But I may be wrong. Link to comment Share on other sites More sharing options...
Benji_vs Donating Members 403 Member For: 16y 10m 3d Gender: Male Location: East Suburbs Melbourne Posted 17/05/11 03:37 AM Share Posted 17/05/11 03:37 AM Is this a generic tune? If so dont use it and get it properly tuned, these tunes which come with the cappa box can cause huge problems, but from what you have described it sounds like a mechanical problem. I agree get the valve springs replaced as the BA's are know to have fairly weak springs. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 16d Gender: Male Location: Perth Posted 17/05/11 03:54 AM Share Posted 17/05/11 03:54 AM BA's have weak valve springs to start with, but once you up the boost and dont make changes to exhaust back pressure (ie dump/cat/exhaust) or intake pressure drop (ie free flowing coolers better pipework etc) the back pressure between the turbo and exhaust valve pushes down on the valve. In simply terms if you have a valve spring with a seating pressure of 10psi (in reality its much higher than that) and have 3 psi of back pressure your effective seat pressure is down to 7 psi. If you Hydraulic lifter is able to provide more the 7psi of "lift" it will open the valve slightly or hold it open slightly after its open.At high revs you have more gas trying too escape, more back pressure, more oil flow to the lifters so all these factor combine to cause the exhaust valves to stay open. the rough running is caused by low compression in the cylinder(s) that have a valve not sealing properly.Thats the simple version of events. Theres a bit more to it but in brief BA1 springs + Higher Boost = Rough running after a high rpm high boost run (it can also happen lower in the rev range depending on how the boost is ramped upNew valve springs with Higher seat pressure will stop this. Link to comment Share on other sites More sharing options...
darkness Member 20 Member For: 14y 5m 7d Gender: Male Location: Melbourne Posted 18/05/11 03:31 AM Author Share Posted 18/05/11 03:31 AM sweet thanks alot guys ill try that and see what happens if it fixes it all good Link to comment Share on other sites More sharing options...
