Next Mod For My Na?
Scar92
  • Member For: 21y 6m 3d
Is grip really and issue with 180rwkw? I didn't even know they made good tyres in 20's..
Yes grip is an issue with 180 and I bet with 4.11's its even worse! I know I had probs with my supercharged AU and it had 180 also.
Just looked up Federal and the only decent one they have in 20's are 595EVO-Federal Link, pity as the rsr's are great tyre as there a semi slick and cheap for what they can do.
  • Member For: 13y 9m 24d
yeah I dont think the tyres are a necessity with 180kw haha. Probably just need to learn to launch it a bit better. Or put some good tyres on a pair of 16s/17s.
I eventually want to do cams so if I get a tune now, I know ill have to get a retune eventually. Not sure wether to save my coin and wait for the cams.
I've adjusted the shift firmness up on the xcal 3, can chirp 2nd now which is a pretty big deal for the na guys :buttrock:
  • Member For: 16y 11m 14d
Chirp 2nd in the wet :stirthepot:
Dillz you've seen videos of my n/a :3gears:
And I've seen videos of you in your G6 :help: hahaha :stirthepot:
Henz + Dump the clutch in the wet = Massive clutch spin
Edited by Scar92
  • Member For: 17y 9m 8d
Lol, I withdraw my previous statement..
Maybe a couple of bottles of NOS in the boot will help bring the weight down over the back wheels and therefor add more grip? Just a thought.
  • Member For: 18y 4m 11d
I would do a cam before you get a custom tune or naaawwwsss. I'm a sparky, and had never opened an engine before I did the cam on my EF XR6. Great mod. Do yourself a favour, go get workshop manual and a cam (seals and lifters while you're at it), should only set you back a few hundred bucks for a regrind and go from there. Nothing will make your six sound angrier than a nice grumpy cam.
  • Member For: 15y 4m 9d
I'd put some decent tyres under it, CAI and a stall if you could afford it. All before the cams and valve springs. Decent rubber makes a massive difference
  • Member For: 14y 11m 17d
Maybe start looking away from the engine for now? As has been pointed out, your next level of mods are going to require larger dollars, and all of a sudden the dollars vs gains do not stack up. Throw a few dollars towards your suspension. Upgrade sway bars, decent shock/coilovers can enhance the driving experience :spoton:
