20X10 Ba Sedan Offset
QWK40L
  • Member For: 14y 1m
Hi Guys hope someone can help,
Recently purchased a set of 20x10s Vertini Hennessey rims for the rear off my ba xr6 turbo.
but theres a problem the wheels go on the rear fine and the guards a rolled, but the actual cap with
the logo Virtini wont fit on due to the thread which holds the wheel bearing being to long.
can anyone tell me if its anything do do with the ofset. thanks
Grind down the end of thread, it is not used anyway as you can see.
I did that with my wheels on the rear, you don't need to take much off.
[/quo te]
Hey,
I was told by a mechanic it can affect the balance of the car, which I think it
wont.
ozzy tyres put me a 5ml spacer but it helped abit, the caps had to be shaved a bit on the inside so they go on. I thought there might be a another way around it.
hi Guys,
Grinded 7ml off the thread, took of the 5ml spacer off but the rim scarpes on the inside know, can some tell me if they use a spacer for 20x10 on there sedans, it just touches I reckon it needs about a 2ml spacer and it will be fine.
  • Member For: 18y 3m 25d
[quo te]
Hey,
wont.
I suppose it could...though there is only a very short amount of shaft protruding from the bearing which is not being supported at it's other end.....so as long as you grind it down evenly it should make the balance better. If you had say 1 metre of shaft sticking out and just hanging there, it would be way out of balance as soon as it started to spin, whereas if you cut the one metre down to 5cm, it would be far more in balance.
  • Dropping a turd
  • Member For: 17y 3m 28d
No, vertini McLaren 20x10 +42 fits perfect, although there is only about 3mm clearance on the inside. A slight rolling of the guards and no rubbing anywhere. What offset do you have.
