Fg F6 Rear Bar Insert Would It Fit A Standard Rear Bar?
Dagabond
  • Member For: 14y 21d
Is it easy to remove the bumper insert , do I have to remove the whole bar
I'm thinking of plasti dipping the insert black with the glossifier over it
If its easy to remove it will save a lot of taping
I reckon it was pretty easy. feel behind the bottom corners and you'll find 2 screw holding it into the rest of the bumper, then 3 scrivet's under the bottom (one in the middle and one either side). Once these are all out the rest is clips into the bumper, just gently pull from one side and once the first clip is out you'll see what they're like and can easily remove the rest. I would definitely give it a go
