Engine Running Rough Hi Rpm
baf6
  • Member For: 15y 9m 11d
Hi guys, im having a problem that happens on occasions, when im givin the F6 a bit of stick and back off the engine runs rough and loses power, usually just back of for a bit and it comes good, mostly happens in 4th or 5th gear.
whats the most likely cause of this, valve springs, coil packs? any other ideas?
I've done a bit of searching and thinking valve springs, if it is the case, what are the best value valve springs, noticed theres quite a range.
Brad.
Edited by baf6
  • flame magnet
  • Member For: 16y 8m 13d
valve springs will do that on hi revs. a sedan with no surge tank will do that if fuel level is under 1/2 tank. old plugs will do that under load.
its rough untill I back right off and slow down, if I accell slowly it runs rough like it's not running on all cylinders.
Its a ute but I do get fuel surge under 1/4 tank, plugs were replaced recently by tuner
  • Menace
  • Member For: 13y 9m 8d
mine does the same.. I'm led to believe it is the valve springs and they need to be replaced with aftermarket springs I think some guys are using crow cams springs,etc..$$$ :censored: .
What is the worst case scenario if encountering valve float here and there after a big rev like baf6 has said?
  • Member For: 18y 8m 2d
dropping a valve into the cylinder and smashing the piston, block and cylinder head
