  • Member For: 20y 8m 21d
HPF dont give stuff about ford tuning anymore, they basically stick some numbers in and shove you out the door.
Take it elsewhere.
  • Replies 30
  • Toughest BA Turbo
  • Member For: 22y 5m 5d
Seems a low results these days.
How about you display the power and boost dyno charts so we can have more information to review.
Brian
  • Member For: 17y 2m 9d
I thought hpf had a low reading dyno? A mates to4z g6 only makes 360 odd on there dyno.
Actually then his motor let go with only low kms and low boost, maybe go with sexr6ts post.
  • 10 months later...
  • Member For: 16y 2m 5d
that's very low for those mods....sound like they may have loaded a generic tune...got to Pitlane mate..should be 300 at least..
  • Member For: 16y 1m 19d
Only second guessing weather the valve springs have been replaced or not as I do not know the full history of the car. only thing my tuner can find is a 8 psi drop through the hot side tubing will rectify and fingers crossed.
  • Member For: 15y 8m 18d
  On 06/05/2011 at 11:07 PM, dre said:
HPF just don't get the numbers like they used too. A lot of the staff changed and it's just not as good.
As per everyone else.GO TO PIT LANE.
I think that's rough, I know Paul, Marty and Matt and they are good guys.
You can loosen the dyno straps and put the intake air temp in a different loacation and easily see 20% variation in power without a tune change, what does the car drive like? I have a customer with similar mods and it only makes 280 rwkW but runs 12.2 @ 113 mph in street trim, tyres etc. Regardless you shoud speak to HPF first if you are not happy, they may have a reasonable explaination.
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 9m 24d
Yep, sounds like a bit low - but you would already know that cos you posted up. Like docs, go for a 2nd opinion. You already have the XCAL3 so all you'd be up for is the labour for another tune (hopefully no parts are farrked) - and I'd suggest Pit Lane as well because I use 'em and Mick seems to get consistently good results :thumbsup:
  • Member For: 16y 2m 16d
what was stock power? if it low as well it this might explain it - Speak to HPF see what they say - RWKW are not every thing if the car did the time you wanted would you still be unhappy with low dyno sheet?
