  • Member For: 16y 7m 8d
Hey guys just got car back from tuner (hpf), 262 rwkw at 14 psi.
Rebuilt 4 speed trans with shift kit
4" dump, high flow cat 3.5" back
Pwr intercooler
Pwr heavy duty trans cooler
Turbo ported and 12psi actuator
Deka 60lb injectors
Crow valve springs
Rapid systems 2.5" hot ic piping
Larger under battery pipe
Walbro fuel pump
Pod filter and cai
Xcal3 tune
Was expecting a bit closer to 300rwkw.... What else can I do besides bigger cooler and intake plenum???
  • Replies 30
  • Member For: 14y 6m 29d
I have less than that and have 340rwks. im going to be the first to say this for once, go see mick at pit lane. mind you I don't go there YET. just going what everyone else would say.
  • Member For: 16y 3m 4d
with those mods I would guess at LEAST a 285 with 14psi
go pitlane everyone talks bout mick
im going to him soon!
Edited by c0lezy
  • Member For: 15y 6m 7d
Take it to Springy Performance if it's easier. Got 285rwkw on my brothers car with just cat and injectors.
Edited by bradles024
  • Here since the start...
  • Member For: 22y 26d
Your result does seem quite low to me also.
I've got just over 300rwkw's on 12PSI with PW stage 2 cooler, pod filter in place of stock airbox, 4" dump, cat and injectors.
You've got the gear to make a decent amount of power and do it with as little stress on the engine as possible.
It might be an idea to get it checked out somewhere else. Just a power run while data logging might show something is a miss.
  • Member For: 17y 3m 21d
Hey man,it does seem a bit low... How high is the stall convertor? My BA 4 spd made 270rwkw with injectors,valve springs and Walbro intank pump with a standard auto/convertor. Something doesnt seem right but one would think HPF would of said something or explained a problem etc.
