  • Member For: 15y 4m 10d
Hey guys as the title states, my engine light has been on for the past month I would say, its an N/A xr6, just wondering what it could be. In the past it had come on but then gone away after a few more k's, not so this time.
car has done over 100,000k 's not sure if this would have anything to do with it or not.
cheers, guys, Sam
  • Member For: 15y 6m 20d
any mods?
take it to your mechanic and get them to scan it for you
or
disconnect the battery and turn the lights on for a few minutes, but don't do this if you have any plans on getting the error codes from a mechanic
  • 3 weeks later...
hmm ok, I had it in at ford on the weekend with a mate, run the ids through the system and found a number of minor faults that would not make the engine light come on(so he tells me) , it did fix it though, until about 1klm away from home and it popped up again.
Another thing is that when I run the flash tuner through it, it turns off, and then on the 2ND startup after I run the flash on it, it turns on about 20 seconds of engine running. f*cked sensor somewhere maybe that the IDS doesnt detect? im not sure, but I will be in at ford this coming friday for a more experienced tech to have a look,
Cheers, sam.
