adrian_celati Donating Members 82 Member For: 16y 5m 24d Gender: Male Posted 04/05/11 12:39 PM Share Posted 04/05/11 12:39 PM Hi everyone, I'm just trying to find the legislation on exhaust systems in QLD on this forum and the net and can't find anything that's got any detail. I'm specifically asking because I want to remove the centre muffler on my xr6t. The guy at the local exhaust shop said it was illegal. Is it the number of mufflers in the exhaust system that's the issue, or the noise, or both? Has anyone stumbled across the legislation? Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/ Share on other sites More sharing options...
Ace blind leading the blind Member 3,657 Member For: 16y 9m 23d Gender: Male Location: Mt Alford, Queensland Posted 04/05/11 09:28 PM Share Posted 04/05/11 09:28 PM its number of mufflers mate - lots of people do it but it doesnt pass adr laws is the trouble Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1102978 Share on other sites More sharing options...
matt036 Donating Members 280 Member For: 15y 5m 27d Gender: Male Posted 04/05/11 10:06 PM Share Posted 04/05/11 10:06 PM As far as I am aware any modification to the exhaust system is illegal but I reckon its all up to the discretion of Mr plod. For example, there's some toss where I live with one of those cowboy utes and he has a straight through exhaust from extractors, no cat, no muffler of any kind and it is loud as fark. You can hear him coming for blocks its that bad. Then another mate had a standard BA but just had the rear muffler removed and cops booked him for undue noise but nothing to do with actually booking him about the exhaust. So really who knows like I have my center muffler cut out and have never had a worry. Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1102980 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 15d Gender: Male Location: Zombie Birdhouse Posted 05/05/11 01:59 AM Share Posted 05/05/11 01:59 AM Not sure about the "nationality" of laws, but fines from the EPA can reach up to $10k for breaches. Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1103029 Share on other sites More sharing options...
xr6greg Member 73 Member For: 17y 13d Posted 05/05/11 02:31 AM Share Posted 05/05/11 02:31 AM Exhaust systems must comply with Queensland legislation which includes the following conditions:• Exhaust headers (extractors) may be fitted to anymotor vehicle, provided:they do not foul any part of the steering, suspension, brake or fuel systems all fittings for emission control equipment (E.G.R. valve, oxygen sensor, pipes and so on) are incorporated to ensure the vehicle maintains compliance with Australian Design Rules for vehicle emissions exhaust systems must continue to comply with relevant legislation or Australian Design Rules for vehicle noise. • The exhaust outlet must extend at least 40mm beyond the furthermost outboard or rearmost joint of the floor pan that is not continuously welded or permanently sealed which could permit direct access of exhaust gases to the passenger compartment, but not beyond the perimeter of the vehicle when viewed in plan.• The exhaust outlet, if to the side of the vehicle, must discharge to the right hand side of the vehicle and ownwards at an angle to the horizontal of not less than 15 degrees and not more than 45 degrees.• The exhaust outlet, if to the rear of the vehicle, must discharge at not more than 10 degrees above or 45 degrees below the horizontal. • All exhaust and muffler systems must be free of any leaks or mechanical faults and should be adequately supported. Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1103038 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 15d Gender: Male Location: Zombie Birdhouse Posted 05/05/11 02:50 AM Share Posted 05/05/11 02:50 AM written by another beerocrat Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1103046 Share on other sites More sharing options...
xr6greg Member 73 Member For: 17y 13d Posted 05/05/11 11:37 AM Share Posted 05/05/11 11:37 AM On 05/05/2011 at 2:50 AM, Buf-Phoon said: written by another beerocrat Actually a 10 second cut 'n paste from the Qld Government QT advisory site accessed by a process called Google... Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1103232 Share on other sites More sharing options...
Craig. Member 563 Member For: 18y 3m 14d Gender: Male Location: Sunshine Coast QLD Posted 05/05/11 12:38 PM Share Posted 05/05/11 12:38 PM So no mention of decibel levels or anything like that Greg? Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1103253 Share on other sites More sharing options...
xr6greg Member 73 Member For: 17y 13d Posted 05/05/11 01:28 PM Share Posted 05/05/11 01:28 PM On 05/05/2011 at 12:38 PM, craiginmackay said: So no mention of decibel levels or anything like that Greg?Simplistic answer is that it must be within the same decibel range of the factory specs + - a small percentage. In other words it must conform to its 'certified' noise level in accordance with ADR 83/00 (from memory).In Qld the method of noise measurement should be found in the Vehicle Standards and Safety Regs and requires an authorised instrument (decibel meter) to be operated in accordance with the National Stationary Exhaust Test guidelines. Around 96 decibels at the specified rev range is about the go. Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1103260 Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 7m 11d Gender: Male Posted 06/05/11 01:26 AM Share Posted 06/05/11 01:26 AM In my experience, the Police generally aren't interested in noise db, amount of mufflers and other technical rubbish (many thousands of cars would be off the road if the rules were strictly applied). However, they do become very interested if you drive like an idiot, or your car is heavily modified, and then they will certainly look for reasons to pull you over/get your car off the road. My T runs only small twin resonators in each pipe at the rear (centre and rear standard mufflers removed), sounds brilliant under load (IMO), very loud/raw above 3,000rpm but pretty quiet below that - its not ridiculous or offensive. I have done a few breath tests/roadside inspections recently with no dramas. With just centre removed you should be fine, its not that loud anyway but it does sound much better than standard (better than most aftermarket systems actually). Just go to another exhaust place mate. ps; Definately do not remove the cat, then you are blatantly illegal and asking for trouble. Link to comment https://www.fordxr6turbo.com/forum/topic/74661-qld-exhaust-legislation/#findComment-1103339 Share on other sites More sharing options...
