  • Member For: 16y 4m 24d
Local bloke in my town has a FG XR6T with PW cooler kit injectors dump and cat at 15psi?please correct me if im wrong Tristan?and its running 327rwkw on 95 PULP,yes that is no typo people and the dyno is calibrated spot on
  • Awesome...
  • Member For: 14y 11m 5d
  On 03/05/2011 at 5:35 AM, Noka said:
Walbro pump it is. So there is a bit of work fitting one of these in a ute yeah? Have to take the tubliner out, then drill out some part of the frame true?
And if I go for a 12psi actuator that should be strong enough to hold the 14 psi boost at high rpm? What does the actuator port mean?
Tobey, that giant hose across the front is my BOV return to the intake.
Much appreciating all this info guys :)
Dont bother with the walbro, use an 044 and a surge tank. The stock pump is fine to feed a surge tank.
Unlike the sendans you dont have to go with a big $ surge tank and pump setup. A $100 tank off ebay with an 044 mounted inside the left tub skin is fine.
The 12PSI actuator is the minimum amount of boost that can be run. This refers to the amount of pressure that is required to open the wastegate.
  • 3 weeks later...
  • Member For: 14y 5m
Have just had the car retuned and 323rwkw. I fitted a walbro 342 fuel pump, a 12psi actuator and the wastegate ported.
Thing is my dump pipe is still stock so now looking into a 4" dumpy and 3.5" exhaust. Would like to hit the 350 mark!!!
