Surging
baxr6ute
  • Member For: 17y 2m 23d
I have a 08 FGturbo ute which has started surging only when first started lasts for couple of hundred meters then stops,been to ford 4 times and still no good,has anyone else had dramas like this????
  • BOOST
  • Moderating Team
  • Member For: 21y 3m 7d
Common thing. More noticeable in a manual. Just give it a few mins to warm up and it will go away once it reaches running temp
  • Member For: 16y 9d
Plenty of other forums about this. Do a search. It is very common. I have found it worse on 95 rather than 98. Ford say they are trying to fix it but nothing yet.
Yes I do warm it up and it has done it when it is still warm,,Had the car 12mths never done it then moved from Adelaide to Townsville...Ford did change a sensor on the waste gate so the say...
  • Member For: 16y 4d
my bf felt like it was surging so I took out the intank pump and found that one of the intank lines had split, fine for everyday driving but as soon as foot went down didnt matter if that tank was full it surged for obvious reasons, being a sedan it was a 20min job to look at the intank pump,but a ute is a whole different story you have to take the tray off to get access to the top of the fuel tank. that's in a ba/bf I dont know too much about fg's sorry :cry: But if your ute isnt using excessive amounts of fuel eg. a leak, then it might be worth a look in the tank... just my experiances I am no mechanic
