Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 20d Gender: Male Location: Perth Posted 15/07/11 02:31 AM Share Posted 15/07/11 02:31 AM Thanks Matt, Totally agree re the tyre/rim width commment. I dont want to go any smaller than a 275 on my 9.5's once the Hugh Mungus rears I have now wear outthis jpc?http://www.jpc.com.au/Todd is running 20 x 10 +42 with 275 on the rear of his N/A, I rolled the guards and it fits perfect no rubbing. A 19 would fit even easier.. A 275 tyre fits nicer on a 10 than a 9.5Arron, any pics of these wheels? what was the clearance like between the control blades and the rim? Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 19d Gender: Male Location: Perth Posted 15/07/11 02:40 AM Share Posted 15/07/11 02:40 AM (edited) http://www.japaneseperformancecentre.com.au/unsure if its my net, or their site, but it's all ffuuccckkked up hahayeah the "muffin" look works on 15s and 16s, but it just damages tyres on larger size rims Edited 15/07/11 02:41 AM by Tocchi Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 20d Gender: Male Location: Perth Posted 15/07/11 02:42 AM Share Posted 15/07/11 02:42 AM Sheesh first your hanging shit on my 4 potters now you telling me I have a muffin top...... Thanks mate will looking to the spacers Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 3m 24d Posted 15/07/11 02:51 AM Share Posted 15/07/11 02:51 AM what were they before? and did you just extend the outer shell?oh ok, ive got 2 to 3mm clearance up front, and about 10mm on the rear -- hell pisses me off ... I want the same clearance on the rear (2 to 3mm).Yep.. mines at 2-3 mmm on the front. Put the spacer in for piece of mind. Ill have to measure the front outer shells. I had these on the rear initially. Could be 2.5 inch ?????Jimmi/Tocchi what 5mm wheels spacers are you using? I would like to push my fronts out 5mm or so to match the rearsSpacers are just repco specials.. cheapies.. they come in 3,5 and 8mmNot the best but will do for nowOkay mr smarty britches... if you where to run a spacer do you have a preferred brand? Did you need to get the offset adjusted or where you able to mix and match your centres and bands to get it as is?Front spacer on mine were just precautionary. Ideally you mix and match the shells to suit. With a 3 piece its possible. But now that Tocchi and to a degree myself have worked it out it should be a no brainer. The shells come in 1/2 inch incrementsThe centres are a standard depth... So you work the rim around it. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 2m 20d Gender: Male Location: Perth Posted 15/07/11 02:55 AM Share Posted 15/07/11 02:55 AM Thanks Jimmi, I dont have Simmons mate. Only china spec 1 piece rims :poke: I would only use the spacers to size them up and then get the rims modded or get the right size rims Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 19d Gender: Male Location: Perth Posted 15/07/11 03:04 AM Share Posted 15/07/11 03:04 AM Sheesh first your hanging sh*t on my 4 potters now you telling me I have a muffin top...... Thanks mate will looking to the spacershahaha xoxoxoxYep.. mines at 2-3 mmm on the front. Put the spacer in for piece of mind. Ill have to measure the front outer shells. I had these on the rear initially. Could be 2.5 inch ?????yeah I can bet you have a 2.5" front as I have a 3" front. which will explain the 0.5" in rim width Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 16d Gender: Male Location: Perth Posted 15/07/11 03:39 AM Share Posted 15/07/11 03:39 AM Thanks Matt, Totally agree re the tyre/rim width commment. I dont want to go any smaller than a 275 on my 9.5's once the Hugh Mungus rears I have now wear outthis jpc?http://www.jpc.com.au/Arron, any pics of these wheels? what was the clearance like between the control blades and the rim?2 mm but seeing it is a 10 inch rim with a 275, the rim is the widest point. I cant belevieve after 2 years and only 2mm clearance with 3 big guys in the back of his car it has never touched. A kumho is a big carcass ,a 275 on a 10 is nearly 285 mm at the widest point whereas a 275 on a 9.5 is only 272mm Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 1m 21d Gender: Male Posted 15/07/11 05:27 AM Share Posted 15/07/11 05:27 AM (edited) Tocchi love the car with simmons on mate., and that nice little sticker on the front left lower spoiler. Edited 15/07/11 05:28 AM by pazzo xr6t Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 3m 24d Posted 15/07/11 09:16 PM Share Posted 15/07/11 09:16 PM hahaha xoxoxoxyeah I can bet you have a 2.5" front as I have a 3" front. which will explain the 0.5" in rim widthSpot on mate.. checked them last night. 2.5 and 3 respectivelyCan you work out the offset from that ? Much appreciated Link to comment Share on other sites More sharing options...
Tocchi Sandtrap Motorsport Donating Members 2,055 Member For: 16y 19d Gender: Male Location: Perth Posted 16/07/11 07:28 AM Share Posted 16/07/11 07:28 AM will do about to head out to visit Monsta Torque so ill do it when I get home for you Link to comment Share on other sites More sharing options...
