  • Member For: 14y 4m 5d
  On 10/05/2012 at 3:04 AM, j.d said:
I went thru 4 rear axles in about a month at one stage, not really sure y they kept bending, wasn't flogging car, wasn't tramping just bending
What was the damage$ to get it repaired?
  • Member For: 14y 10m 20d
Can't remember would have a receipt somewhere from memory like $hundred and something for a new one and install but don't quote me on it
  • FREAKY
  • Member For: 15y 5m 22d
is there someone who makes stronger ones, would rather get something else rather than fords sh*t
  On 10/05/2012 at 5:40 AM, PAZZOnegger said:
What are the symptons of a bent axle?
Mine is bent and I have end float which is allowing my disk to have run out. (Basically my car is squeaking constantly when I drive)
  • Member For: 14y 1m 17d
if you want to no how to get ride of axel trap take alittle more practic in your take off it took me nearly 2 years to master mine. now I can play with the revs in ay gear and never get axel trapm. mines the lowest ute I have ever seen and its manual. I got my tailsharft balanced and cv's changed for 500kw and its never had a problem touch wood.
  • FREAKY
lowest ute you have ever seen? any pics? need proof lol.
where did you source your 500kw cvs?
and what does balancing your tailshaft do to help?
  • Banned
  • Member For: 13y 7m 3d
I would like to hear more on this theory on not jacking up on the rear of the ute. if I put a jack under or right beside the leaf U bolts on the diff housing, how the hell is that going to put load on youre axels? there is never any load on the axels at any time, that's what wheel bearings are for.
cheers, andy
  • Member For: 16y 6m 25d
Andy, of course you can jack the ute up. Just do it one side at a time an avoid jacking from the diff or axels. The factory jacking point for the ute is actually the chassis.
The load of the car is always transferred through the jack so you are going to stress whatever you are using to lift the car.
Still dont believe it? Simple experiment. Put your hand between the car and the jack and start to raise the jack. If it hurts I'm right. It's no theory it's physics.
