  • Member For: 16y 3m 22d
so in 2012 solid rear axels are made out of spagetti.... a diff so weak you supposedly cant let the axels recieve any down weight?? this is fck sh*t...
  • Like 2
  • 2 weeks later...
  • 1 month later...
  • Member For: 14y 4m 4d
Just found out I have bent axles in the rear of my ute.. The noises got worse the other night after I took it to the drags.. It does axle tramp a lot when I launch it hard of the line. Any ideas on what I could add next time to stop it from tramping as much and hence bending axles? Don't really wanna fork out the money for a tramp rod kit. Would new shocks and bushes in the rear be of benefit to strengthen it all up? Any help would be appreciated!
  • Member For: 14y 10m 19d
^^^ this, mine doesn't tramp to often, but it is annoying when it does!!
Who does tramp kits? And cost ?
Edited by j.d
Jase I know Mal Wood does a kit for $899 but obviously very expensive just to eradicate the tramp.. I was thinking along the lines of adding a whiteline rear sway bar and new bilstein rear shocks. Would this help?? Anyone??
  • Member For: 14y 7m 24d
Was told when very low they bend axles and break tailshafts, but then take JDs one of the lowest and it's all good. Is it manual? and if you have warranty are you going to try to get them replaced through ford?
