  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 29d
when the turbo -manifold studs become loose or lost it effects the car so bad u wont know what hit u once there fixed
I had replace all my studs on my ba cause there were 2 missing and yes u get used to the car being lazy but once I fixed them it went so bloody well I forgot how good it was to have full boost once again
this is why maintenance on the manifold side is so important to keep the b series running so well
  • Replies 32
  • Banned
  • Member For: 14y 5m 6d
Exactly JETSNOT - my car was the same about two years ago - amazing difference. Sort of blows you away and makes it frustrating that you didn't get around to it earlier...!
PS; Just looked at your old BA and new F6 performance listings - any reason why they are so close in times despite a massive rwkw difference? (I am thinking about upgrading to a F6 - of course its a better car than a BA/BF in every way, but just not sure its adequately faster to warrant it (for me) just yet)
Cheers.
Edited by CBXRT
not gunna hi jack the thread but iam running the std f6 cooler and it fell over at 1/2 track (heat soak) so the mph doesnt reflect what it did on the dyno :bangcomputer:
the fg sh*ts all over the b series and on cold mornings it flys but I definately need the aftermarket cooler asap ...........I did it on the cheep big time so it was a rocket out the gate but died after
Edited by hiddeous
Quote Removed Use fast reply or add reply button!
  • Member For: 17y 3m 19d
OK Guys,
Supercheap cheapest - $69 :shocked:
I rumbled through my stuff and have a 3" 0-100psi gauge that should do, plus some lengths of hose and tube and fittings.
Next dumb question - Where is the easiest place to temporarily tap into pressure?
I've had a look around under the bonnet and there are no obvious spots jumping out at me.
  • <put funny sh*t here>
  • Member For: 18y 5m 20d
the small vacuum line that goes to the top of the Blow Off Valve. Just t-piece into that line. OR the line that goes into the regulator at the back of the fuel rail, t-piece off that also.
Well, no boost checking for me now.
The engine went into limp mode (I think) on the way back from shops this morning when I picking up the tee piece and some silicone hose.
Gave it a little squirt in 1st, started spooling up, then there was a popping noise and power was gone. It ran like a ragged dog on 3 or 4 cyl for a minute or so till I found somewhere to pull over.
I switched it off, rang the workshop telling them something very serious was definitely happening, then after ~10 minutes, restarted it and it is running fine again.
I have been for a short drive since and the turbo is still spinning up, but I'm not going to drive it any more except to the workshop on Monday morning.
Over boost I'm guessing.
Hopefully they'll get to the bottom of it and I'll get my old T back.
Edited by John K
OK ratter,
You win - first reply!
Finally the guys in the worshop found their mistake today and plugged the actuator hose back in.
That's why it was boosting off the scale.
That's why the spooling was noisier.
All fixed. My old T is back.
Thanks guys.
  • Member For: 18y 11m 1d
:yahoo: What do I win ? :yahoo:
Just glad you got it sorted out with out to much hassle, despite what a few think of these cars, stock, they do not normally go like you described
:beerchug:
Would love to know what PSI you were running then :) May have caused some damage to the motor, did you notice any pinging while it was boosting hard?
