  • Replies 32
  • <put funny sh*t here>
  • Member For: 18y 5m 7d
fit a cheap mechanical boost gauge with a rubber line off a t-piece. just run it into the car through a window or something and see what its boosting to :)
  • Here since the start...
  • Member For: 21y 11m 20d
  On 27/04/2011 at 10:44 AM, hiddeous said:
Maybe they fitted a police chip last service...?? :)
Or they connected the wire by mistake! :roflmbo:
  • Member For: 17y 3m 5d
Huh! Connecting one wire! Those engine tuning companies must be making a killing!
  On 27/04/2011 at 10:56 AM, ratter said:
Auto or manual?
Not many stock auto's will light the tyres in 2nd gear.
ZF auto. I had it tramping in 2nd today.
  • Banned
  • Member For: 14y 4m 24d
  On 27/04/2011 at 6:01 AM, dule said:
CB your stock T breaks traction in 2? Is this on gear shift or as it comes on boost?
Mate, my BA auto doesn't break traction per se in 2nd, just has the TC flicker around 3,000rpm or so when it comes on boost (its not a hp monster!). When I say stock, it runs a K&N filter, basically no mufflers, larger dump pipe, 98 ron and better intercooler - mine has nothing like the power of serious players on here, hence why I say its mostly stock so as to not embarass myself! :surrenderwave:
All I was really pointing out is that all Ts I have driven should have traction issues in 1st, and maybe second/third depending on power, and that I think John's car was seriously ill before it was fixed!
If that was the case, it's been seriously ill since new.
The grunt it has now is verging on silly (for a gentleman driver such as myself).
It starts whistling on 1/4 throttle and if the road is damp I have to be somewhat cautious when giving it a squirt.
If the surface is dry, I'm starting to go sideways giving it a squirt during a gentle curve.
The traction control doesn't seem to be dealing with it well and it's going sideways already before the T/C light comes on.
I've booked it back at the shop to get the waste gate actuator checked out once and for good.
Edited by hiddeous
Quote removed Use fast reply or add reply
  • Member For: 17y 11m 30d
Do what someone already suggested, buy a cheap $20 boost gauge and just hook it up through the window and see what boost it's running, if it's more than 5-6 psi you have a problem. It's cheap and takes about 5 minutes to hook up.
